Pride Of Cucamonga
- Cheap piece of junk Spanish (Tecatel) 120cm(x110) dish, Inverto Ultra twin LNB and Sky HD box.
- Valencia (city)
thanks, would these be the correct f/D ratio as Miika explained?
thanks, learning a lot. according to woborny, an offset should be good enough for the area, but I'm getting very poor resultsExactly. Or you can buy new one, which matches with your dish. Need to know dish f/D ratio.
Offset LNBs works, if signals are strong, but are not suitable for weak transponders and fine tuning. Offset LNB can "see" only middle part of prime focus dish, therefore collecting about or less than 50% available signals.
Feedhorn must be metal, other materials do not collect signals. If there is plastic addings, these are just for weather protections.
