Hello all sorry I haven't replied in a while.. and many thanks for all the suggestions. Work has eaten into my satellite fiddling time!
So I checked all angles again. still nothing. Next I will have my receiver tested..
The only other thing I can think of Line of sight.. Nearest obstacle is 50m away and 30m high.
Could that cause complete lack of signal?
Checked in the hope that perhaps they were installed the wrong way round. Nope. The top one is the input and drives the motor. The loopthrough is as labeled the bottom one. No motor power.. no anything really.
No signal no quality.
- 1 Week Ago 08:52 AM
I think we need you to upload some photos, as unless the receiver is faulty, or you have changed the LNB settings to something incorrect, you must be doing something wrong.
Which satellite are you lining up on for your due South? Have you looked at the setup guides in the sticky threads section at the top of this section?
I will do when I have some more time and once the receiver is checked. I'm 95% sure it's all right though..
I haven't changed anything in the LNB settings.. Power is on, diseqc is off (it's a single LN
Should I change any LNB settings?
I have lined up to true south, used USALS to co to a satellite then tweaked with the manual motor buttons and a signal meter. Verified satellite with satfinder app and compass.
Any other ideas plesae do let me know.. I'll post again with the receiver test results.
