Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
Satellite PC Card Receivers, Internet by Satellite
Power off before connecting LNB?
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="NoviceSat" data-source="post: 910318" data-attributes="member: 390074"><p>I destroyed my TBS 5925 USB tuner as the (ready-made) LNB cable I was using snapped at the connector end and shorted the inner and outer parts. <img src="https://www.satellites.co.uk/styles/default/xenforo/smilies/sad.png" class="smilie" loading="lazy" alt=":(" title="Sad :(" data-shortname=":(" /></p><p></p><p>The TBS device stank of halogens for weeks (blown capacitor? I couldn't check as they use 'special' screws to keep the case together)</p><p></p><p>I wish I turned the power off beforehand as they're not cheap devices! <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite14" alt=":-doh" title="DOH! :-doh" loading="lazy" data-shortname=":-doh" /></p><p></p><p>Now I use my old Technomate receiver which has LNB short circuit protection. I check all cables I make using this device - it only takes one strand of copper to start causing problems...</p></blockquote><p></p>
[QUOTE="NoviceSat, post: 910318, member: 390074"] I destroyed my TBS 5925 USB tuner as the (ready-made) LNB cable I was using snapped at the connector end and shorted the inner and outer parts. :( The TBS device stank of halogens for weeks (blown capacitor? I couldn't check as they use 'special' screws to keep the case together) I wish I turned the power off beforehand as they're not cheap devices! :-doh Now I use my old Technomate receiver which has LNB short circuit protection. I check all cables I make using this device - it only takes one strand of copper to start causing problems... [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
