Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
DISH SETUP: Single sat, Multi-Sat & Motorised
Problem Setting Up Portable Satellite Receiver
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mike1" data-source="post: 112254" data-attributes="member: 190179"><p>When using the dish make sure the lnb is push forward to the dish as much as possible. Because them screenshots looked like it was too far away. </p><p></p><p>I good tip for aligning to astra 1 19e is put it on MTV Central and the meter will give you a rougth idea where the sat is the elevation I used was 31 degress now I get 80% on Astra 1 in yorkshire <img src="https://www.satellites.co.uk/styles/default/xenforo/smilies/smile.png" class="smilie" loading="lazy" alt=":)" title="Smile :)" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="mike1, post: 112254, member: 190179"] When using the dish make sure the lnb is push forward to the dish as much as possible. Because them screenshots looked like it was too far away. I good tip for aligning to astra 1 19e is put it on MTV Central and the meter will give you a rougth idea where the sat is the elevation I used was 31 degress now I get 80% on Astra 1 in yorkshire :) [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
