t67
- Nov 25, 2007
- Age
- 49
- db500s
- UK
Right checked them m8,and nothing at all...Glitch free..No break up or freezing....Robbo71 said:Yes, thats what I meant, just see if you can watch all the FTA channels OK without picture problems.
(exluding the low bit rate t!tty channels of course)
Yeh m8,its when I am running gbox..Not sure how I can find out how much space I have on /var..But on the memory info it says 3.6m free,if that helps any.sorry m8I will try n install another emu tonight as wont be back home tilmhku said:Is your lock up when using gbox? Try installing another emu e.g. CCcam, get the latest keys and compare the same channel using the different emus....
How much space is left in /var?
late..Failing that will give it a go tomorrow...Cheers
