Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
Satellite PC Card Receivers, Internet by Satellite
Progdvb & vPlug help Required
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="cgo372" data-source="post: 618344" data-attributes="member: 271651"><p>Yes Skystar 2 DVB PCI (4.5.0) does work with Vista 64bits as well as it works with windows 7 RC 64bits. The trick is how you install the driver...I tested DVB Dream, DVb viewer and DVB prog and they are doing OK, the more stable is DVB Viewer. About Vplug, since the end of T*S, I haven't installed it again as I don't see the point anymore.</p><p>The trick on the driver installation with Windows 7 is to remove the driver enforcement, install first the driver from the version 4.40 in the device manager, it will be installed with error code 10, and then update the driver with the version 4.5.0 directly from the device manager. Once done, install the full package 4.5.0</p><p>hope it helped, cgo372</p></blockquote><p></p>
[QUOTE="cgo372, post: 618344, member: 271651"] Yes Skystar 2 DVB PCI (4.5.0) does work with Vista 64bits as well as it works with windows 7 RC 64bits. The trick is how you install the driver...I tested DVB Dream, DVb viewer and DVB prog and they are doing OK, the more stable is DVB Viewer. About Vplug, since the end of T*S, I haven't installed it again as I don't see the point anymore. The trick on the driver installation with Windows 7 is to remove the driver enforcement, install first the driver from the version 4.40 in the device manager, it will be installed with error code 10, and then update the driver with the version 4.5.0 directly from the device manager. Once done, install the full package 4.5.0 hope it helped, cgo372 [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
