yeshu26 said:here we goView attachment 39175
Robbo said:If the dish in the picture was focussed on 4.8E, and you picked up 19.2E on the offset lnb, you would not be able to get 28E, as the LNBs would need to be further apart, i.e the offset bar is too short.
Also, offset LNBs should point at the middle of the dish roughly, not wonky like yours.
TBH, any meters that may be cost effective to buy, would not be much better than your beeper. For DIY use, you are better off just using your sat box and old tv. You can identify the sat by what channels can be received, and tune to particular tranponders.
Robbo said:Yes of course as nano says a separate dish is the easiest, cheapest and a guaranteed way to
get what you want.
But, if you wish to persue the offset LNB approach just for fun, then yes the LNB bar needs extending by the sound of it.
Firstly though, you need to get that bar fixed on properly, borrow a drill. Get both LNBs on there. The LNB shouldn't point towards the edge of the dish, it must point inwards towards the centre.
Tivù said:I seem to remember positing the simple solution of the second dish as far back as ............................ Post #3![]()
Robbo said:The focal point of the dish
is where the main LNB is. When the dish is aligned to a satellite, the waves bounce off all of the dish and end up at the focal point.
But when you have an offset LNB, the whole of the dish is still used, but signals from satellites not on boresight, bounce off the dish at an opposite angle to the angle of incidence. They don't come to a focus though, more like a fuzzy cloud.
The LNB has an area of the dish that it illuminates, like a conical beam, if it isn't pointing to the centre of the dish, you will illuminate thin air, and thus capture less signal from the dish.
and yes, a sky box can be used for FTA on 28E.
Another photo perhaps, with it fixed on properly?
Wouldn't touch a beeper, they're crap.
yeshu26 said:Indeed. But it was more about experimentation.
yeshu26 said:Will the box still need a card for tuning purposes?
