Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
Satellite Systems - What to Buy - What to install
Satellite system advice needed
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Art" data-source="post: 509118" data-attributes="member: 286696"><p>I took all your knowlegable words of wisdom into carefull consideration and with the financial help of my 32 year old son ( he likes mature content and footy) <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite13" alt=":-rofl2" title="roll on floor :-rofl2" loading="lazy" data-shortname=":-rofl2" />and so we have ordered a full motorised system built around the Technomate TM5400,basically because after a week of reading about receivers I tend to think that model will be easier to patch and update via USB.</p><p></p><p>I bought it from Wizzard satellite,which had an offer of £149.00 including free postage, the setup is as below:</p><p></p><p><strong>Technomate 5400 CI+ USB PVR receiver</strong></p><p><strong>80cm solid Dish </strong></p><p><strong>Technomate 2200 Diseqc 1.2 motor</strong></p><p><strong>.2 Universal lnb</strong></p><p><strong>Wall mount</strong></p><p><strong>30m Cable, clips, bolts, amalgamating tape, connectors, rawplugs, cableties ect .</strong></p><p></p><p>I will probably invest in a monoblock LNB and will depending on my neighbours good will ( party wall) if he wont allow me to use it I will have to get a dish pole to get me over the side of the gable end of our house.</p><p>So in 3\5 days you may see a post saying "Help required"<img src="https://www.satellites.co.uk/styles/default/xenforo/smilies/smile.png" class="smilie" loading="lazy" alt=":)" title="Smile :)" data-shortname=":)" /></p><p></p><p>Thank you all for your good advice...Arthur</p></blockquote><p></p>
[QUOTE="Art, post: 509118, member: 286696"] I took all your knowlegable words of wisdom into carefull consideration and with the financial help of my 32 year old son ( he likes mature content and footy) :-rofl2and so we have ordered a full motorised system built around the Technomate TM5400,basically because after a week of reading about receivers I tend to think that model will be easier to patch and update via USB. I bought it from Wizzard satellite,which had an offer of £149.00 including free postage, the setup is as below: [B]Technomate 5400 CI+ USB PVR receiver[/B] [B]80cm solid Dish [/B] [B]Technomate 2200 Diseqc 1.2 motor[/B] [B].2 Universal lnb[/B] [B]Wall mount[/B] [B]30m Cable, clips, bolts, amalgamating tape, connectors, rawplugs, cableties ect .[/B] I will probably invest in a monoblock LNB and will depending on my neighbours good will ( party wall) if he wont allow me to use it I will have to get a dish pole to get me over the side of the gable end of our house. So in 3\5 days you may see a post saying "Help required":) Thank you all for your good advice...Arthur [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
