Someone to fit and align my dish..Wirral nr Liverpool
Labno
Technomate w/1100mm dish Diseq 1.2
Merseyside
Hello,
I'm after someone to set up my 1100mm motorised dish i live on the Wirral close to Liverpool if anyone knows anyone or can recomend a firm let me know.
Cheers,
Adam
I need someone to tell me if i can have a motorised dish at the back of my terraced house as i think the roof will be in the way of the signal can anyone help ???
Welcome to the forum scudda
Why not post a photograph of the back of house indicating the compass bearing
ok ill get a pic done tomorrow but south is facing the front thats were all the sky dishes are facing
I put one up today, it was a sharply pitched roof, so required around 5 foot of mast above the gutter, but pulled in all of the satellites, due South was pretty close to straight towards the front of the house.
You can work it out using measurements of the roof.
pedro2000uk said:
We cover that area if you haven't got fixed up yet.
Pedro - How do I contact your company? Local to Knutsford.
Try activating your Vcard option in your profile information, that way you can be contacted :)
Done - thanks
ok heres my pics of the back of the house
_http://s474.photobucket.com/albums/rr103/scudder_02/?action=view&current=house2.jpg"
_http://s474.photobucket.com/albums/rr103/scudder_02/?action=view&current=house.jpg
If you wish to use photos, please upload them as per the forum rules. Admin
Would welcome guidance as to how to contact you - considering a system upgrade. Thanks
This may help you and others.
You can find out which way the dish will need to point and work out if things are in the way.
you can find you house by post code and address the position the satellite icon exactly on the side of the house that you want it on.
You can the change what sat you are checking from the drop down box.
If you click on the show obstacle line checker it gives a little help in seeing if you can clear obstacles.
_www.dishpointer.com_
