SWMBO Is Pleased!
To continue the saga, all was well when I went in to the garage this morning, down to -20C and in the green, took some stuff out to the dryer and plugged that back in, an hour later went out to the garage to check the clothes and discovered the freezer was only -10C. Notice it was a very old type of plug, so thought I would check it and sure enough the cable tug had pulled the live out of the pin. Took all connections out recut and stripped insulation back refit into plug and freezer now running at -20C, this time I ensured that the cable grip/clamp was tight and hopefully this is the end of the saga, well at least until it does fail properly.
