Technomate and CAS
going to be oline for a bit so any problems
stevo
stevo
Just dropped you a mail (thanks), but should it matter when I go into CAS system and under Conax, that I do not see a channel listing as I do in the other systems e.g. Seca, all I get is the conax option and then the tables appear.
neovo said:
HI I also have technomate 5500ci super with joe fields patch v3.
Is there a new patch yet or software tools update keys via pc.
thanks!!!
HI
please would you email me a link to this patch for my TM 5500 CI ?
cheers
Hope this helps , i have a Technomate 5500 super that is patched, i found it tedious to update using the remote so i invested in a matrix reloaded cam , off of e-bay. I also invested in a cas 2 interface and a infinity pheonix card programmer, m2 card and tit card.I just update the cam and the cards as nessesary now takes a few minuets . Watching nearly everthing that can be watched.Ok it costs a bit to start with but its worth it for the ease of use
