Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
DISH SETUP: Single sat, Multi-Sat & Motorised
Technomate motor LED flashing orange
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Lazarus" data-source="post: 789292" data-attributes="member: 323322"><p>Not unless it is particularly badly exposed ----------- the saving grace for you is the aluminium construction which should mean that in anything but severe conditions the motor won't be unduly overloaded. </p><p></p><p>The usual spec. is "Up to 1.2m" and the limiting factors are dish weight (governed by whether it's steel or aluminium - big difference) and wind loading which is dependant upon size alone (for practical purposes).</p></blockquote><p></p>
[QUOTE="Lazarus, post: 789292, member: 323322"] Not unless it is particularly badly exposed ----------- the saving grace for you is the aluminium construction which should mean that in anything but severe conditions the motor won't be unduly overloaded. The usual spec. is "Up to 1.2m" and the limiting factors are dish weight (governed by whether it's steel or aluminium - big difference) and wind loading which is dependant upon size alone (for practical purposes). [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
