- TM 5402HD
- Scottish Borders
What are you trying to watch?
can you please tell me more about the TM online menu ?
cheers rob
is there a better make of receiver i can buy ,( not technomate) ) that will work correctly ?
what do you mean chris ?
but i was already recommended to buy the 5502 amongst others, so i did.. but its not playing properlyHe means "click anywhere on the blue text in his Post" ....... ;)
not being funny, but it was William who recommended the 5502, so it has a known blind scan problem ??.. wish i had known that.. its a deal breaker for me..You could try looking out for a TM-5302, its very similar to the TM-5502 but does not have the problem with the blind scan. The useful thing about the TM-5302 and the TM-5502 is that they accurately report the frequency and SR which is handy for feed hunting. Some of the other Technomates are not as accurate in this respect.
Forum member "William-1" is very knowledgeable on all things Technomate so if he pops along to this topic I am sure you will get some expert feedback.
Follow this guide:-
Download the latest Phantom patch & either save your channel list or use mine then proceed:-
Factory reset
Load the latest patch
Factory reset
Switch the receiver off at the mains for 30 sec to drain all the power in the receiver
Now load a channel list
Set up your motor settings
You will now find that the receiver will respond better to your commands.
I do this with all my satellite receivers to remove the previous software.
