- TM Nano ~ sg2100
- Midlands
How to use SBCL with a Dreambox
Introduction
It is possible to watch TPS with a Dreambox. To do this you need to install SBCL/ vplug on your PC and to modify a config file on your Dreambox. You will then to put the new TPS files onto your PC each day.
This guide will use CCcam; it is possible to use other cams if you modify the relevant config file (See appendix not done yet).
Prerequisites
1. Download SBCL/ vplug from here:
_http://dvb-upload.com/index.php?action=preview&pid=101399
or from your preferred satellite download site.
2. Download the latest TPS files from your preferred satellite download site.
3. Find your router here:
_http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
PC Setup
1. Install SBCL and amend the path in plugins\vplugin.ini to match
2. Put the latest TPS.bin, tps_fns and v_tps.db into the plugins folder
3. Start SBCL (click on the SBCL .exe)
4. Click on the tuner tab and enter your Dreambox IP address
5. Set protocol to newcamd
6. Click the START button
7. Select vplug from the menu bar and select ACTIVE
8. Select vplug from the menu and select SHOW MONITOR
Dreambox setup
1. Install CCcam if not already done.
2. FTP /var/etc/CCcam.cfg to your PC
3. Add this line to your config file usng your IP address (do a FIND on SBCL in the file):
N: 192.168.1.2 6001 test test 01 02 03 04 05 06 07 08 09 10 11 12 13 14
4. FTP CCcam.cfg back to /var/etc/ on your Dreambox
Date/ time.
1. Open a telnet session to your Dreambox.
2. Type date
3. Set your PC to the same time as your Dreambox
Router setup- optional
You may need to configure you router for port forwarding on port 6001. Setup forwarding on this port to your PC's IP address.
For details on how to do this for your router see here:
Firewall
You may need to enable port 6001. For some reason I had to allow port 1034.
Test
With SBCL running on your PC, go to a TPS channel and set CCcam as the default cam.
In the vplug Monitor/ SBCL window you should now see SBCL sending the keys to your Dreambox and you should be able to watch TPS channels
Updating
Stop SBCL and put the latest tps_fns and v_tps.db files into the plugins folder.
Restart SBCL.
Other
You need to update tps_fns and v_tps.db on a daily basis.
p.s. any errors- please post them in the Dreambox General Section.
Click here for Index
Introduction
Prerequisites
PC Setup
Dreambox setup
Date/ time.
2. Type date
Firewall
Test
Updating
Restart SBCL.
Other
