Tivù Receivers and Smart Cards
a link with pakage list, and coordonte sat for tivu ,knows somebody
nice day!
Hi!
I have a query. I do own a satellite receiver called Clarke-Tech 2000. (_http://www.clarke-tech.com/produkte?template=detail&entryid=2&lang=]CLARKETECH.com - Produkte )
It does have a s slot Common Interface but I do not know if it is compatible with the SmarCam. Any advice?
Many thanks!
Hi, I don't know if you can help, but I am having a problem with my Humax 9000 combo. I bought it in Italy with ti vu sat card and all has been fine, until now. it has started updatig and I can not stop it. The remote will not work mwith it nor the buttons on the front of the machine , is there a way to do a reset?
I have just bought a combo myself this week and had the same problem while setting it up. I eventually left it and forgot about it for a couple of hours and it sorted itself out. I think it spends time looking for the update and it is either a very slow processor or it cannot find what it wants! Since I have had annoying problems like that in changing channels when it just hangs for as much as half a minute while it decrpts the signal. I bought Humax because of flawless reception on my previous 2000 HD receiver but slightly disappointed with the performance of the 9000. It works perfectly on the terrestial channels mind but not so good on TiVu Sat.
