tm600 help!
chinywhite
newbiee
uk
hi i need some info on the tm600 what channels can i receive
what softcams can i use
do i have to use a card or can i put emus and softcams thankyou
A nonymous
If you think the TM600 will open all channels for nothing then you are going to be disapointed.
You can receive what ever channels the receiver can pick up but as for encrypted channels it will only open what ever the card in it will allow.
It may also open a few other bits and pieces on emu, but this is dwindling fast.
The TM600 will work with CCCam, gbox, mgcamd, newcamd, evocamd, and virtually any other softcam that will run on the Dreambox.
:-beer
Nano
chinywhite
newbiee
uk
hi need help wht firmware shell i put on
chinywhite
newbiee
uk
nano could giv me bit help on cards
A nonymous
You only have a few choices at the moment. Either DS or UR.
There are other Dreambox images that have been rejigged to work on the TM600 or TM500 but i wouldn't bother with these until you have learned how to use the box.
Both DS & UR images are good, its jsut down to user preference.
:-beer
Nano
