bobon said:What about lowering the wall?
probably easier than putting in a new pole.
You really need to walk around with a clinometer and a compass... Or go on dishpointer, zoom right in and put the dish in a few different positions and then see what the minimum heights of the obstacles are.garyg said:You think just going further back and abit higher will clear ok then?
Yeah that's it... Or, for example, for 26ºE, guessing an elevation angle of 26º for your location, if the wall is 2 meters high the satellite can be seen from ground level (dish rim touching the floor) when 4.1 meters from the wall.garyg said:26E the wall can be 1.3M... So erm yeh! theres the issue...
So say the wall is 2M... the bottom of the dish would need to be 0.7M off the ground correct?
They're on Hotbird. You could get them with a mini dish.garyg said:Cheers mate, hopefully I get it, then i will put my 1.2m on 7w for Verticles for my Al Jazeera sports card, champions league!![]()
