- UK
but its less likely right since sky box better components than cheap satellite receivers such as manhattan?
Is there a corner nearby ?
but isnt the card meant to be skys property since it was in box when i bought it?
there is plently of space for the fansIs there a corner nearby ?
my sky+ hd box is one of the models from 2016 so it should be okay right?Cobblers - the receivers are all built using components from the same factories. And if you dont believe me there is historical evidence from all the capacitor failures from a bad batch of caps which started about 12-13 years ago.
Google capacitor espionage if you dont believe me
it depends because i think the card might be an freesat card?I cant believe you are actually asking that.
Sky are hardly likely to drag you through the courts just because you have a card provided to someone else. They would have to nab everyone who scraps boxes or flogs them at a boot sale.
Oi Sky! Ive got at least 4 cards acquired from various sources & scrapped boxes which you are most welcome to reclaim if you can be bothered.![]()
