archive10
The positioner was handed to be by a postman on a moped on saturday morning (through a kitchen window, but that's not relevant).This is not service at all, it is just a try to assist to some crazy hobbyists. My pleasure.
Even faster delivery than some well-known German sat pushers!
Thank you @RimaNTSS!
From the documentation, the device looks very much like a positioner for smaller sat-dishes.
It does not (readily) accept an external power supply, but relies on what's on the coax going in.
As far as I can tell from the somewhat sketchy (google translate from Russian?) documentation, it even has a 0.6A limiter built into the circuit, so an external power feed would make little difference.
Nevertheless, it is aimed at people with multiple LNBs on a motorised dish, e.g. with Ku-linear, Ku-circular, and C-band on the same dish.
Just not clear exactly what dish would yield good results on all three, and still be moved by a 0.4A current to the actuator? (Except from a limited arc-range dish, of course).
EXCEPT if you have a dish with an LNB changer, then you WOULD want to have a DiSEqC switch built into the positioner.
As I see it, this could be ideal for the LNB changer people using devices with linear actuators swtiching betweeb LNB 1,2,3 and 4...
