Xtraview Keygen !
Of course, I may be completely wrong about this, in which case no doubt I'll be corrected shortly.
Not strictly the case as a certain antipodean billionaire will confim I'm sure.
Having said that there are strange things afoot on 28'E at the moment with
channels from his package popping up FTA at random intervals, and I'm faily sure
it's meant to be like that as they don't often make mistakes.
L.
Well it's just another great marketing strategy, isn't it? Give everybody who doesn't pay anything a pay channel for a little while then, when they've all got used to enjoying that, make it a pay channel again. In fact, I might try that with my customers ;)
Hmm, but if 70% of the Sly boxes sold didn't receive any encrypted Sly channels then would Uncle Ruppe make them all FTA?
Daft analogy I know but it is the same scenario.
I think he actually would for a strategic period.
Seemed to work the first time.
L.
i just got freeview the other day and w as also wondering how i can get xtraview free
i would like redhot channel too but my box cant be manually tuned :(
any help would be apriciated
What make of box is it?
Have you search the menu options for add channels or similar?
Unless it's really, really old you will be OK to get the SPL channel.
my box is the philips dtr500
i have looked in the set up but all i can find is auto scan
That should do it - 'scan' then check the list of channels for 'channel 57' Setanta.
aha i will check that out dude
thanks i will get back to you in about 10 mins when i try it out
ok that one worked :D
cheers bud
is there any way like that to get other xtraview channels i would really like the discovery ones
The Discovery channel is part of TopUpTV (TUTV) and as such isn't available without subscription.
That said, it is sometimes shown as part of Xtraview 'taster' channel - which has been compromised.
This involves obtaining a dump of code (changed daily) and posted on some sites (not here).
When this is entered into the Keygen along with the number generated by your box, with open that service.
Red Hot and Setanta also clear using this method.
But this will change when Xtraview will be closed soon and Setanta move to card access only - within the next few weeks.
Enjoy while you can!
live is so unfair sometimes hehe
ah well thanks much dude
"This involves obtaining a dump of code (changed daily) and posted on some sites (not here). "
Any clues?
i read in a differant post that modshack.co.uk would be of some interest for stuff like that but its closed login
zooma said:
Any clues?
The one I know doesn't allow new members - have you tried a Google search - sure you'll find something.
The dumps rely on someone each day and sometimes they don't appear - you take your chance - like most things with this hobby.
what will happen if you enetered a wrong code ? is like a mobilphone or something where you get so many trys to get it right and if you get it wrong they lock you out?
jahobo said:
they lock you out?
They don't know your doing anything - it's one way.
If it locks you out, change channels and then go back - another number will be generated - enter that into the keygen and try again.
ive never found the keygen nor the pid for the channels
do you know them?
can you tell me in a pm ? thanks
Qué? Tepid and Xtraview clear by entering the PID's given earlier in this thread, but in all honesty, it's not worth the effort. Tepid really is not what you're looking for - you could show it to your granny, and Xtraview finishes on 31 August according to TopUpTV web site.l
