cmuzik said:
Both cables from quad LNB worked when connected to old Foxsat HD. The problem occurred when the new Foxsat HDR tried to connect to quad LNB during set-up wizard. I accept that this could still be a faulty LNB with output working but not input.
Just had a similar experience with a Quad LNB Zinwell on Foxsat HDR. Existing system working with a an old Sky single LNB and loop through to the second. Bought a kit (avaoid trouble with LNB mount adapters for my old dish, by getting a matching set) to upgrade to quad LNB to be able to use both tuners fully
When it was all connected up and aligned, the picture was fine and the diagnostics showed 85/60 for Strength/Quality. To try and get the system to recognise that it now had two feeds I started the Freesat Tuning option. Now the signal would show 85/60 for 10 seconds or so then drop to zero while in the 'detecting satellite' step and would eventually fail.
I spent a lot of time up and down the ladder rechecking everything and retrying. The box was effectively dead as I could not even view previous recordings until it recognised some channels. Although you can exit from the 'detecting satellite' step you just get stuck when it can't verify the postcode. It looked quite bleak...but
I tried using exit to get to the postcode then waiting until the signal was showing and then entered the postcode (success) then tried the channel search (fail). After a few more tries I got lucky with the timing and got the channel to start being recognised. Once this had started it seemed to hold the signal and complete. Not all channels were detected, but all the ones I have any interest in watching were.
After the channel detection had completed the box worked as normal. Diagnostics steady at 85/60 for Strength/Quality.
I am still in single LNB loopthrough mode, but at least I can watch new and recorded programs.
Next step is to get the system to recognise the dual input...hopefully without needing a full reset, but that is another thread.
FYI the box was on 1.00.17 firmware which is the current latest.
I suspect that I will replace the LNB as others in this thread seem to have done. The workaround may get somebody else out of a hole.
