Anonymous_1
ACM DATA (continuous probably)Something is active at 12537V, i cannot lock it, can anyone check it?
Smile of a child back on the 10718 H 10000 mux
I know some of you don't like offset dishes, but locked this in the Midlands on the CM1.8 with the little Freesat receiver.Maintaining a solid lock on this today, Smile of a child has blank screen at the moment.
Maybe not so wrong.Currently there is one channel 11580H (not sky sport)
I know some of you don't like offset dishes, but locked this in the Midlands on the CM1.8 with the little Freesat receiver.View attachment 104319
Sure you will get a good result when tweaked. Quite pleased with my results seeing as I'm not using a pukka CM feedhorn and C120 LNBI like off set dishes I have enough of them 2.4 1.8 3 x 1.2, My 1.2 can see it but wont lock it, as for the 2.4 getting slightly more signal than that, its not correctly lined up and using a 20 yr old lnd, plenty of room for improvement when the rain decides to stop.
Will take a look..Might not in KU band scopus, it could perform poor if its only spun for C band, if it doesn't perform well in KU it will be coming back down, Could you check weak signals from 7W please and post up for me to check, noticed a thread in fringe reports
Now 11580H is Sky sports 1Maybe not so wrong.
Unfortunately I can t lock it and check this mux by myself but according to the ID and the previous test at 26°E few months ago on 12380 H .(Sky on OTT @ 26°E) Sky sports and more channels are probably embedded in this stream.
Just an idea...
