- See Signature
- Somewhere in England (possibly?)!
You are not the onlycertainly not as good as it was ..and to make matters worse ...I don't speak imoji.
Although DAT and DDS tapes are mechanically identical and the DDS drive may be able to read DAT tapes I am very dubious it will be able to write data to a DAT tape. IIRC DDS tapes had a leader which told the drive what spec (DDS 1, 2, 3 etc) and used a lot higher quality tape from DDS2 onwards than DAT - original DDS1 tapes (same as DAT) only hold 1.3GB whereas your DDS3 tape drive holds 12GB . Are the tapes actually DAT tapes or do they have a DDS logo on them?Took a break from the Chameleon ...and powered up the DAT unit ..
It accepts a DAT tape ..so in this respect ...a positive ..
I have physically installed the scsi card in Chameleon ...and according to XP is recognised in System/Hardware...and is flagged as recognised and working properly ..
I guess I just need software now so that windoze can access and talk to the DAT drive ?
Time for a break ..
Dr Who to watch..
lol
Sony DDS data cartridge DG-60M by way of example is the one I inserted last night..Although DAT and DDS tapes are mechanically identical and the DDS drive may be able to read DAT tapes I am very dubious it will be able to write data to a DAT tape. IIRC DDS tapes had a leader which told the drive what spec (DDS 1, 2, 3 etc) and used a lot higher quality tape from DDS2 onwards than DAT - original DDS1 tapes (same as DAT) only hold 1.3GB whereas your DDS3 tape drive holds 12GB . Are the tapes actually DAT tapes or do they have a DDS logo on them?
Hi Evan, unfortunately the Backup Exec tape software that I have found is for Netware servers so no good to you however I did find win 95 Colorado installation disk and HP Colorado II for win 98, I suspect the latter will be more useful to you and am happy to post to you if you need it so just PM me your address and postcodePM sent..View attachment 106334 Hi Evan, unfortunately the Backup Exec tape software that I have found is for Netware servers so no good to you however I did find win 95 Colorado installation disk and HP Colorado II for win 98, I suspect the latter will be more useful to you and am happy to post to you if you need it so just PM me your address and postcode
Errr ..Do you need your head cleaning, VS?![]()
That makes it a DDS4 drive or later. Although it should be able to read your tapes. the drive may not be able to 4write reliably to them. The tapes should have a rating on them DDS3, 4 etc.Must be my day for impulse buying ..
Someone one flea bay was selling a used untested DELL DTS-10000 ..
Now as far as I know ..SDT is the Sony standard ..
and is therefore possibly a re-branded Sony drive ..
I didn't really buy it for the drive ..though this will be interesting in itself..
max 40gb storage ..
fast scsi interface ...
But I really bought it so as to rob the 5.25 inch bay mounting kit ..
At £2.00 plus postage ..I figured ..might as well..
Dont think so Stephen ..but thanks for the offer ..In my shed there is a Colorado (or what is badged Colorado) 5 GB device in caddy. Any use to you ?
ImageBam
