Spanish TV
w hole
uk
Hello All particularly Ex-pats in Spain
Can anyone give me a good link for Spanish TV Schedules.
I have been using :
http://www.cplus.es/codigo/television/television.asp
But I find it a bit hard going.
In the main I'm looking for films that might be on Canal+ and Cinemania.
Regards
W Hole
chris
TalkTalk TV
Worksop UK
Try-
http://www.eurotv.com/
If you'd have used the search function on this forum , you would have found this-
http://www.satellites.co.uk/scripts/webforum/DCForumID17/32.html
enjoy
chris
w hole
uk
Thanks Chris but....
Euro TV doesn't seem to cover the channels I mentioned.
Back to the drawing board.
Any other suggestions anyone?
Regards
W Hole
Try this w hole, http://www.cenansergiu.com/
Rolf
w hole
uk
Thanks Rolf but...
nothing there either.
regards
W Hole
w hole
uk
FYI
I have found this one :
http://www.tvinteligente.com/parrilla_intro.php
Looks quite good
Regards
W Hole
