Hispasat 30W-6
s-band
Essex
If you want to have a look for it, here are the predicted passes for London
Upcoming passes for HISPASAT 30W-6
Observer: Home,
LAT:London
 AOS                  TCA                  LOS                  Duration  Max El  AOS Az  LOS Az
 2018/03/08 17:30:38  2018/03/08 21:54:01  2018/03/08 22:23:17  04:52:39   44.78  207.13  107.45
 2018/03/09 13:22:30  2018/03/09 16:26:51  2018/03/09 17:28:18  04:05:47   19.22  133.83   83.06
 2018/03/09 20:04:14  2018/03/09 23:57:08  2018/03/10 00:23:01  04:18:46   38.23  232.26  128.86
 2018/03/10 14:40:24  2018/03/10 18:37:23  2018/03/10 19:36:38  04:56:13   36.13  172.30   90.29
 2018/03/11 00:15:00  2018/03/11 02:08:26  2018/03/11 02:21:02  02:06:02   23.87  266.41  162.30
 2018/03/11 16:40:02  2018/03/11 20:54:22  2018/03/11 21:39:15  04:59:13   45.11  200.69  103.10
The epoch time for the above is 03:54 2018/3/8
Real time: Real time satellite tracking for: HISPASAT 30W-6
s-band
Essex
Plots of the beacons as it crossed the Clarke belt. Doppler at the time made frequencies seem a few kHz high.
The actual position was close to the predictions.
Hispasat_30W-6_1923_11448a.jpgHispasat_30W-6_1925_10701a.jpgHispasat_30W-6_8-3-18_1926.jpg
s-band
Essex
Here's another whist it was much closer at around 7100km. Much stronger, possibly receivable on a LNB only (no dish). Note: scales changed from previous plots.
Hispasat 30W-6 should be at the 26.0°W in-orbit test location now.
reza1
starmax
42e
ayak izi
MODERATOR NOTE - Please post in English.
ayak izi = footprint
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
This is why I like it here, proper technical discussion!
Never thought i'd meet a group of people as sad as me.:-rofl2
satellite now 27.90 w
s-band
Essex
Not if its stopped & the tle's havent been updated yet!
Celestrak TLE epoch is 16/3 14:01 so a couple of days old and puts it at 30W. The beacons peak a bit to the east of 27.5W so it is probably at 26W.
tle now hispasat w6 31 w not curect
the tle update satellite now 26 w iot soon
HISPASAT 30W-6
NORAD ID:
43228
LOCAL TIME:
20:12:41
UTC:
20:12:41
LATITUDE:
-0.04
LONGITUDE:
-25.99
ALTITUDE [km]:
35789.88
ALTITUDE [mi]:
22238.8
SPEED [km/s]:
3.07
SPEED [mi/s]:
1.91
AZIMUTH:208.9 SSWELEVATION:
+26.8
RIGHT ASCENSION:
06h 11m 43s
DECLINATION:
-08° 24' 49''
Local Sidereal Time:
07h 55m 55s
The satellite is in day light
SATELLITE PERIOD:
1437m
Adam792
Cheltenham
Any sign of anything from 30W-6 yet? I wonder when it’ll move across and replace 30W-4.
Current tracking suggest not.
HISPASAT 30W-6
NORAD ID:
43228
LOCAL TIME:
23:39:22
UTC:
22:39:22
LATITUDE:
-0.01
LONGITUDE:
-25.97
ALTITUDE [km]:
35782.44
ALTITUDE [mi]:
22234.18
SPEED [km/s]:
3.07
SPEED [mi/s]:
1.91
+26.8
RIGHT ASCENSION:
11h 12m 35s
DECLINATION:
-08° 17' 07''
12h 56m 44s
SATELLITE PERIOD:
s-band
Essex
26W
I think that this is its Ka beacon on 20199MHz Circular
Finally Hispasat 30W-6 left IOT location 26.0°W, and will arrive at 30.0°W in a few days.
Yesterday's TLE confirms Hispasat 30W-6 arrived at 30.0°W.
Adam792
Cheltenham
Apparently most stuff has moved over from 30W-4 to 30W-6 now according to Flysat.
I'm noticing about 0.5dB less signal on the TDT Sat transponders (12548V, 12631V, 12671V etc) than usual. This might be that my dish has moved a little bit though.
Have the official footprints turned up anywhere yet?
MCelliotG
Thessaloniki, Greece
The three aforementioned are now quite stronger at my location, coming at 16db. The rest have not moved (yet), Flysat is wrong!
