Home made diseqc positioner
dreambox1959
46.3N-4.3E-FRANCE
france
does it is the AX-HD51 is the diseqc master ?
i read your posts on DXTV Forum :
power reduce for lnb changer. etc ..
The LNB changer is a Technirotor which is a DiSEqC 1.2 motor? It should work directly from the dreambox1959 positioner with no extra V-Box :confused
dreambox1959
46.3N-4.3E-FRANCE
france
no , suedschwede has build a changer where there is only motor , limit switch and reed switch no board with microprocessor .
for those who need more than two jacks i have thought of an additional card to add to my basic positioner.
  • posi4052B.pdf
dreambox1959
46.3N-4.3E-FRANCE
france
hello to those who followed me in the realization of the positioner (JPCPOSI).
-I have optimized the transfer of EEPROM data from a PC.
-I have created a PC software for reading / modifying / saving data.
-I improved the management of DISEQC orders.
tell me where you are in your construction.
dreambox1959
46.3N-4.3E-FRANCE
france
here is good job made by Suedschwede !
DIY positioner
zorrin
Specialised contributor
France
www.facebook.com
france
Just started mine :)
11bc0bd8-2ca6-4d3c-817a-b3ded21b6e05-jpeg.139584
danny10
Amiko Alien 2,E - 85,Famaval 110 ,IBU twin
Czech republik
Hello,
can i ask for a 1x set? 2x superjack max.36V for CM 240, skew control Chaparall corotor II, transport to the Czech Republic.
Thank you.
dreambox1959
46.3N-4.3E-FRANCE
france
Hello,
Thank you.
what do you want ? my positioner !
do you already have actuators and dish ?
i m an hobbyist , i m not a sat retailer
7mdish
Milan, Italy
If you want, I have a Chaparral Corotor II in very good conditions, used for just few months well protected against rain.
danny10
Czech republik
yes, please, your positioner.
I know you're just a hobbyist, but you have already built a positioner for the guys from this forum.
I have everything - actuators, corotor and channel master 240. I'm not in a hurry. Thank you.
dreambox1959
46.3N-4.3E-FRANCE
france
hi dan!
i ll send you a positionner , so inside the eeprom memory i ll put 2000 as index for every sat cause i don t have any datas for your mount !
when you use it for the first time select a sat by name and move the dish for the right place.
send me some pictures of your mount .
JP
dreambox1959
46.3N-4.3E-FRANCE
france
hi danny10
your positioner is on the way !!!!
post here some pictures of your mount and dish .
dreambox1959
46.3N-4.3E-FRANCE
france
i still have a positioner 90% builded . + some printed board .
does someone need it ?
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
Hello dreambox1959,
I am currently still looking for a mounting frame for the display, so my further construction of the positioner has come to a standstill. Do you still have sources for the mounting frame?
best regards
suedschwede
dreambox1959
46.3N-4.3E-FRANCE
france
two ways for a mounting frame :
cut yourself in a plastic box front face (or thin aluminium)
or buy a superb front face from schaeffer . that s what i do.
Schaeffer AG Frontplatten Designer
dreambox1959
46.3N-4.3E-FRANCE
france
for anyone who had my "JPCposi" I had made improvements and fixed errors in the firmware so buy a USBASP programmer (less than 10 euros) and make a programmer cable
Hi JP, does this apply to the firmware you did for me?
butchyboy
channel master 1.8m motorised on c band,ku band,1.2 metre prime focus irte dish, 1.85cm offset mabo dish,vu+duo & 42 HD lcd tv
ireland
how much?.
also can i move my dish manually by pressing button on the front to move my dish rather than not using disqec signals.
dreambox1959
46.3N-4.3E-FRANCE
france
how much?.
OF COURSE YOU CAN MOVE THE dish with the front panel keypad and remote control
