- Elite 2.2 PF with Multi lnb changer - CM1.2 - Gibertini 1.25.
Ku - Ka - Ext Ku - C & Ext C. X.
PC cards 6983,6903, main receiver GTX Combo. Ericsson RX8200.
Promax HDRanger+ & HDRanger2 Analysers.
- North Nottinghamshire. UK.
The cable came from the motor into my TM5402 box then using the loop out port into the Combo. I assume it's bad practice messing around with the coax cables whilst the box is on but i've done it hundreds of times without issue on other boxes. I was going to flash the box from my PC but to my disbelief amongst the myriad of cables I have I can't seem to locate a USB to USB and haven't had a chance to get one yet
>>The cable came from the motor into my TM5402 box then using the loop out port into the Combo. <<
The Combo's Terrestrial socket likes to give volts out of it but will be very unhappy to have a dose of 13/18volts fed into it's circuitry delivered from the TM5402's loop out socket. It could well be the end of it
