Unfortunately I have no way of giving you a measurement in db’s, my receiver and meter just give strength and quality in %.Please post some details, channels, and signal quality readings, from available satellites, 1W, 5E, 7E, 9E, 10E, 13E, 16E, 19.2E, 23.5E, 26E, 28.2E.
Try using the excellent list, by william-1:
Just Sharing This - Strongest transponders
same here,rainy weather and midday time mean weak reception for 7w and it strengthens a lot after 7pmsatellites.co.uk
Pole is definitely plumb and yes, the motor is at zero on reference.First, about the pole: is it completely plumb, east/west-wise? (an issue that Terryl already mentioned)
Second, with a USALS setup I would check (in fact, before all other mentioned tests):
On a diseqc 1.2 Goto-Zero or Goto-Reference command, does the motortube in fact go to exactly Zero?
And in that motor position, does the dish seem exactly in line with the line pole-motor?
And does the dish arm seem to be exactly in line with the line pole-motor-dish?
A deficiency on those points could mess up a motor setup considerably.
Greetz,
A33
Indeed. So check what is wrong at the extremes, but make the adjustments only after rotating the dish to 1.0W. Quality could alsoalways tweak on 1w, not at the extremes. sounds like you're getting there...nice one.
You can if you want (I have done it as well), but it is tricky and can be confusing and you can easily end up in a situation whereAs far as I'm concerned: you can tweak dish declination at the extremes.
But indeed, after that, adapt the motor elevation again at the center of the arc (at due south/ 1W for you).
This is a repeated steps procedure of tweaking the dish declination angle (at the extreme), and then take compensatory action on the motor elevation (at due south).
Greetz,
A33
These days, I tend to rely on measurements for all but the very final tweaks.
Another solution is to use a mux with a frequency on which both H and V is transmitted.
Can you receive the one I mentioned ?Is the K1 beam worth playing with?
Seems to be significantly weaker.
Yes 92% Strength 70% Quality.Can you receive the one I mentioned ?
