gdf68
- Jun 4, 2023
- Age
- 55
- 1m dish Digipower SG2100A TM2600 GM twin Lnb, GT media 8uhd, vuo duo, Xtrend 8500. GM SR525HD Nvidia Shield Sport feeds
- Liverpool
Finally got hold of a piece of scaffold, so can reinstall my setup
Wall is not very flat but found a section but I have got to the the K bracket at the top to get it level
T bracket will be at bottom , is that ok.
Then attach the mast before installing the T and levelling it all.
Once I have this done
Does it matter which order you put the motor and dish on the mast as long as bang in the centre.
Oh once again cheers Alex
