astra 1p 19.2e
Check the information I put, then zero channels.
When you saw 2, now there are 6 channels, one pending (Astra Caption).
It looks like they had to leave it running this weekend.
What satellite are they on now?
Verifique la información que puse, entonces cero canales.
Cuando lo viste 2, ahora ya son 6 canales, uno pendiente (Astra Caption).
Se ve que lo tenían que dejar funcionando este fin de semana.
En que satelite están ahora??
Telegold one music tv
It on astra 1n
Update of the Astra 1P maps at 19'2ºE./Actualización de los mapas del Astra 1P a 19'2ºE.
Our Coverage | SES
Since it is in dbw, I leave the antenna measurements in cm for that signal from other maps.
Como esta en dbw, dejo las medidas de antena en cm para esa señal de otros mapas.
High-SES-ASTRA1-P-Ku-band-Pan-European1
High-SES-ASTRA1-P-Ku-band-Pan-European2
High-SES-ASTRA1-P-Ku-band-Europe-Widebeam
Our Coverage | SES
The Maps now show the more powerful beams over certain areas (Portugal, Central/South Spain, Central Romania).
Our Coverage | SES
This more clearly , thx a lot
Around 4:00 UTC, txp 47 and 120 were transferred.
Txp-47 11171 H 1L --> 1P
Txp-120 12728 H 1L --> 1N
From the check at 6:30 UTC (7:30 Italian time), I can only confirm that the txp-47 has moved towards 1P.
While for the txp-120, I have less certainty because 1N and 1L are very close, it needs further checks to confirm.
Vertical
Horizontal
Vertical
Horizontal
Lyngsat, Flysat and Kingofsat all say 11171 H, 10832 H and 11229 V were/are on 1KR. Do you think this is correct?
Now Txp-47 11171 H is on 1P because i never have signal on this freq.
Txp-120 12728 H is more weaker for me now.
Only txp-41 is on 1KR. In the last few days also some transponders used for feeds, have passed on 1P, like txp-9 and txp-26 that were previously on 1L.
These are the checks I made yesterday:
February 5, 2025, 9:40 UTC.
Vertical
Horizontal
February 5, 2025, 14:00 UTC.
Vertical
Horizontal
February 5, 2025, 19:00 UTC.
Vertical
Horizontal
If you look carefully at the images, you can understand which satellites they come from.
Those sites which you mentioned , they take a while to update their channel lists, unlike this forum you will find all new updates on real time
Yes and sometimes they don't report the same data.
On Hotbird 13F Kingofsat and Flysat say 12731 H is on the SE beam and Lyngsat says the wide beam.
In my opinion it's definitely on the SE beam.
Just an example and off topic (sorry for that).
From the check just done (12:00 UTC), you can already see a small difference of the txp-120, compared to those still on Astra 1L (green arrow). Even if 1L and 1N, they are very close (they are just 0,02° apart). In the late evening, I plan to do a new check, when they should be about 0,04° apart.
Vertical
Horizontal
I notice that the frequency on which the orf channel was on is worse by more than 1.2 db on the 1.8m antenna in Slovenia after the move.
The new frequency is 11303/22000 H fec 2/3, which means the signal is 1.2db worse than the old frequency.
