astra 1p 19.2e
photo my freinds 3.8m aignal after transponder move 1p
11303h on 1p only 8 c/n weak signal
Astra 1L is starting to move away to the east, I redid all the measurements of the telemetry and beacon signals, of the various satellites. I realized that I had previously made a mistake, I inverted the telemetry signals of 1L with those of 1KR.
The Telemetry/Beacon signals at 19,2°E, are associated as follows:
Astra 1KR = 11196.00 H (TM+Beacon) / 11712.00 V (TM+Beacon)
Astra 1L = 11205.00 V (TM+Beacon) / 11445.50 H (TM+Beacon)
Astra 1M = 10943.50 H (TM+Beacon) / 11708.50 (TM+Beacon)
Astra 1N = 11441.00 H (TM+Beacon) / 11453.00 V (TM+Beacon) / 11703.00 V (Beacon)
Astra 1P = 10956.00 V (TM+Beacon) / 11449.00 H (TM+Beacon)
?? no 11303 on astra 1 on kingofsat??? nearest is 11332....
It's ORF Digital on 11303H
Btw ask kingofsat the reason why, and then tell us :p
Check tle of astra 1L it start move
it tp 9 11332h feed use 1p
0.04465 2025/02/19 17:05:16
2025/02/20 16:18:00 2025/02/20 17:54:00 MID_BOX A1L 19.38 N/A 1 0.030 0.02166 2025/02/20 17:05:24
2025/02/21 15:54:00 2025/02/21 18:19:00 MID_BOX A1L 19.40 N/A 1 0.030 0.00354 2025/02/21 17:06:08
next two day 1l start move
From the TLE data, it seems that Astra 1L is entering an inclined orbit... with that 0,1° inclination it is right at the limit of the geostationary orbit. In the coming weeks, if it continues to increase, it will mean that it is entering an inclined orbit.
In the meantime, Astra 3B is already in an inclined orbit, having exceeded 0,1 degrees.
If we examine the launch data of Astra 1KR, 1L and 4A (formerly Sirius 4), built on the A2100AXS platform, 1L is the one that consumed the most fuel during the LEOP phase, having an perigee of only 250 km.
Astra 1KR Date launch: 20-04-2006 vehicle: Atlas V - Hp/Ha: 6212x35786 i: 23,97° - Platform: A2100AXS - Separated Mass: 4332 kg
Astra 1L Date launch: 04-05-2007 vehicle: Ariane 5 - Hp/Ha: 250x35952 i:6° - Platform: A2100AXS - Separated Mass: 4497.5 kg
Astra 4A Date launch: 18-11-2007 vehicle: Proton - Hp/Ha: 7030x35786 i:17,3° - Platform: A2100AXS - Separated Mass: 4385 kg
The same is true if we examine the launch data of 1M and 3B, which are on the same platform (E3000), the 3B, launched aboard Ariane 5, had an perigee of only 250 km and not by chance has already entered an inclined orbit.
Astra 1M Date launch: 05-11-2008 vehicle: Proton - Hp/Ha: 4980x35786 i:21,5° - Platform: Eurostar E3000 - Separated Mass: 5320 kg
Astra 3B Date launch: 24-03-2010 vehicle: Ariane 5 - Hp/Ha: 250x35786 i:3° - Platform: Eurostar E3000 - Separated Mass: 5471 kg
In the last few days, there have been several feeds, on transponders 9,24,26,28,30 and 32. So I was able to make measurements, to establish from which satellite they are emitted.
Txp-9 = 1P
Txp-24 = 1M
Txp-26 = 1P
Txp-28 = 1M
Txp-30 = 1N
Txp-32 = 1N
In the last few days, there have been several feeds on 19,2°E. I have been able to identify most of them, on which satellite they came from. To my surprise, I found that transponder 16 is on Astra 1KR.
For those interested in the feeds on Astra 1KR, there is currently one active on frequency 11429 V, SR 9875, FEC 3/4, Modulation DVBS2/8PSK. It is not in clear, but encrypted in BISS.
This feed has been turned on in the afternoon for at least 4 or 5 days.
FTA feed on 11.650 V, SR 9600, 4:2:2
what channel use feed biss ?>
There is no rule, the one that broadcasts free, if they discover it the next day, it could be in Biss, those that broadcast in 4:2:2 usually maintain the format and do not switch to Biss, these last Germans in general, you need a PC with a satellite card or a receiver that allows streaming to the PC like Enigma2.Feed with reference ITA xxxxx whatever they usually use Biss in general.
Here you have a website that almost has the links up to date, in general they have their hours, excluding international events and weekends.
In this subforum I put the links that I see active.That last from 10 minutes to hours.There are many events on weekends, from lunches with Olaf Scholz, football matches, skiing, the 80th anniversary of Auschwitz, Mass for the deceased Dana in Spain, the German elections, it was crazy, there was not enough time to put them all up.Minimum antenna for the Astra at 19'2ºE, 85cm and some of them nothing, better with a bigger antenna.
No hay regla, el que emite libre, si lo descubren al día siguiente puede que este en Biss, los que emiten en 4:2:2 suelen mantener el formato y no pasar a Biss, estos últimos Alemanes en general, se necesita un PC con tarjeta satelite o un receptor que permita streaming al PC tipo Enigma2.
Feed con referencia ITA xxxxx lo que sea suelen usar Biss en general.
Aqui teneis una web que casi los tiene al día los enlaces, en general tienen sus horas, quitando eventos internacionales y los fines de semana.
En este subforo pongo los enlaces que veo activos.
Que duran de 10 minutos a horas.
Los fines de semana muchos, eventos de todo tipo, desde almuerzos con Olaf Scholz, partidos de futbol, esqui, el 80 aniversario auschwitz, Misa por los fallecidos Dana en España, de las elecciones Alemanas, una locura, no dio tiempo a poner todos.
Antena mínima al Astra a 19'2ºE, 85cm y ya algunos nada, mejor con mas antena.
Mirar arriba la foto nevada, vi todos los saltos de esquí, por no repetir la foto aqui.
