Try registering and entering your card details to see if they accept it.
As I indicated, in the astratv.es notes, it stated that the payment is €72 per year and the customer is responsible for the bank charges for payment. As I indicated, this opens the door to orders from abroad.
I sent a question to Padredefamilia a few minutes ago: if you buy it from them, they'll send it to you abroad.
I'll comment on the answer.
But anyone who wants to can do it themselves.
Last night, a forum member who already had it activated (Gigablue Quad 4K) commented that it only lets them watch/record one channel.
One person from an island indicated that the installer told him that more cards can be ordered associated with a household and that they get a discount.
Intenta dar de alta y meter los datos de la tarjeta para saber si la admiten.
Como indique, en las notas de astratv.es, ponia que el pago es 72€ anual y es el cliente quien asume los gastos bancarios para el pago, como indique, abre la puerta a pedidos de "fuera".
Les mande hace unos minutos una consulta a Padredefamilia, si se la compras, te la mandan al extranjero.
Ya comentare la respuesta.
Pero el que quiera la puede hacer por su cuenta.
Anoche comento un forero que ya la tenia activada (Gigablue quad 4K) que solo le deja ver/grabar un canal.
Uno de una isla indico que el instalador le comento que se pueden pedir mas tarjetas asociadas a un domicilio y tenían descuento.
I forgot, to support HEVC broadcasts in HD and the "La1 UHD" channel, the receiver must support H265, which is complied with by 4K receivers and also have CI+.
Que lo olvido, para soportar las emisiones HEVC en HD y el canal "La1 UHD" el receptor tiene que soportar H265, esto lo cumplen los receptores 4K y tener CI+ tambien.
Solo tarjeta...card only
Incl. 1 año de suscripción Comprar Módulo CI+ de Astra TV | Los canales TDT españoles por satélite Astra 19,2ºE | ✓ Tienda & Distribuidor Oficial
padredefamilia.com
pcmcia+amiko compatible receiver, official receiver at the moment there is no official receiver without an installer visit.
pcmcia+receptor amiko compatible, receptor oficial de momento no hay sin visita de instalador.
Incluye: ✓ Módulo CAM Astra TV ✓ Decodificador compatible Comprar Astra TV con Receptor compatible | La TDT por satélite Astra 19,2ºE
padredefamilia.com
Price and equipment from this distributor; installers can install other compatible receivers; please consult with them.
Precio y equipos de este distribuidor, los instaladores pueden montar otros receptores compatibles, consultar con ellos el tema.
