VMA Stream Reader
New version: https://vma-broadcast.com/wp-content/uploads/2025/04/VMA Video Analyser Setup - 2025-10-13.zip
2025-10-13
- VMA Stream Reader
- Added remote HTTP access - enable/configure via "remote.cfg"
- VMA Transport Stream Analyser
- VMA Mosaic
- VMA Video Analyser Package
Note: You need to edit the "remote.cfg" file to ENABLE remote functionality. It is switched off on purpose!
The easiest way to do it is to go to C:\Program Files\VMA Video Analyser and copy "remote.cfg" to the Desktop. Open in text editor and set:
# Remote enabled (True/False)
Enabled = True
Also, chose your pin! This is the pin you need to enter to access the remote screen.
New version: https://vma-broadcast.com/wp-content/uploads/2025/04/VMA Video Analyser Setup - 2025-10-14.zip
2025-10-14
- VMA Video Analyser Launcher
- New app to launch the main apps over HTTP - configure via "remote.cfg"
This tool can be minimized to the tray and listen for requests.
From any remote computer, tablet or smartphone, it is now possible to launch VMA Stream Reader, VMA Transport Stream Analyser, VMA Mosaic or VMA Video Analyser.
The apps are monitored and can not just started remotely, but closed as well.
This allows for true remote monitoring in professional environments or, in case of DX fans, to handle the antenna while keeping an eye on the results.
For this to work, it is mandatory to edit the "remote.cfg" file contained in the programs folder, which is write protected by Windows! You need to either edit as Admin (Notepad++ will handle this automatically) or, easier, copy the file to the Desktop, edit and copy back to the programs folder (Windows will ask for permissions).
The default setting of "remote.cfg" is to have remote access disabled.
New version: https://vma-broadcast.com/wp-content/uploads/2025/04/VMA Video Analyser Setup - 2025-10-16.zip
2025-10-16
- Now shows thumbnails of the running apps
- Allows to launch multiple apps - automatic port increment
- Many improvements
- User Guide
All apps can now be started, stopped and monitored in one single page.
From here it is possible to individually remote control each app.
Multiple apps can be started, they are assigned an individual port number.
New version: https://vma-broadcast.com/wp-content/uploads/2025/04/VMA Video Analyser Setup - 2025-10-21.zip
2025-10-21
- VMA Macro Interpreter
- New app to run macros on
- VMA Stream Reader
- VMA Mosaic
- Allows full automation of these apps
- First release
Manual is lacking, need to write one later.
If you press F5 on any app (F6 for VMA Mosaic, as F5 was already used), tags with the names of the controls will be shown, to help identifying which is which.
Use the CATALOG button (after establishing connection to one of the apps) to download the catalog of possible commands:
New version: https://vma-broadcast.com/wp-content/uploads/2025/04/VMA Video Analyser Setup - 2025-10-21b.zip
2025-10-21b
- Added Macro Recording (start/stop with F9: all clicks are recorded in macro)
Press F9 to start recording and again F9 to stop recording: you will be prompted to save the recorded macro:
This works for VMA Stream Reader, VMA Transport Stream Analyser, VMA Mosaic and VMA Video Analyser.
It should make it much easier to create simple linear macros that just replay a sequence of commands.
Of course you can then edit such a macro and add extra commands, conditions, waits, etc.
Again, I cannot fully grasp all potential of this new macro language implementation.
Also, the macro language implementation is actually just a show case for the underlying OLE/API. It is actually possible to interact with VMA Video Analyser via OLE/API from other software.
There are certainly many bugs and oddities, but only with use will they show, so I can correct them.
Attached is a first draft of the manual.
New version: https://vma-broadcast.com/wp-content/upl…02025-10-23.zip
2025-10-23
- VMA MacroEngine
- Many new commands
- Bug fixes
More specifically:
New control flow: WHILE / ENDWHILE, ELSE / ENDIF
App control: APP.LAUNCH, APP.STOP, APP.WAIT, APP.ISRUNNING
Checkbox helpers: CHECK, UNCHECK, ISCHECKED
File operations: FILE.READ_LINES, SPLIT
String, math, format producers: FORMAT, MATH, STR.*
Chart and spectrum producers: CHART.GET, CHART.GET_SERIES, SPECTRUM.GET
MSGBOX command for user dialogs
Dear VMA,
I just requested a VMA Video Analyse license (for Private/Non-commercial use) and received your reply. Thank you for your quick response..
When can/should I pay the fee mentioned on your website?
You don't have to pay because you qualify for a free license.
@all: if you are a forum member for longer than 6 month with more than 50 posts, you qualify for a free license. But you need to mention your username and forum name, otherwise I cannot tell who you are.
To try, start VMA Stream Reader, connect tuner, select desired satellite.
Press F2 and select Channel Scan.macro from folder C:\Program Files\VMA Video Analyser\Sample Macros.
Do not cover the VMA Mosaic window, otherwise the screenshots will show whatever is covering the panels!
The process (spectrum, Auto Scan, producing the HTML page with screenshots) might take between 5-20 minutes, depending on the amount of found transponders, tuner used, etc.
You can set the Auto Scan preferences, along with any other Settings BEFORE starting the macro.
Feel adventurous: expand the macro with your preferences!
I might be missing something here, apologies if so! I'm trying out VMA Stream Reader with my new TBS5930 Lite. It seems to work well. I can lock MIS/PLS transmissions - but for some reason I only see one MIS stream available in the dropdown at a time -
This Rai transponder on 5°W should have stream 1, 3, 5 and 11 - if I blindscan again I sometimes get one of the others, but only ever one at a time. I'm trying to tune to stream 11 for the DAB+.
[OT]
Hi, the RAI Tp has streams 1-3-5-11-12. The new stream was added a few weeks ago and for the moment carries Rai DAB as stream 11.
[/OT]
