Paksat 1R 38E
pride21
Sandown Isle of Wight
hi all trying to get new channels so i thought i would have a go at paksat 1R,well i was a bit shocked,to pick up any channels on that sat,anyway i got sun tv at 3986V,dhoom news at 4055V i also picked up aruj tv but no video or sound.
Blimey thats good going.
Calling VS :D
pride21
hi i forgot to say about the 31.5 degrees on the picture it was the old turksat at 31.5,i cannot change the degrees only the sat name.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hmmm ...
Just possible as its within my scope ...but am a good bit further North ..
My cutoff point is 40 East for most C band channels ...as the troublesome tree comes into play beyond 42 degrees
I will obviously be giving it a go ...but reception is never favourable on Eastern birds..
Nice catch...&..cheers for the info Pride..
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
A forlorn hope for me I'm sorry to say ..
Started at Express AM1 40East ..
Entered Sun TV's data into the the F15 ...and single stepped to the west about 30 clicks on the Vbox ..
That should easily cover Paksat 1R ...
Not a squeak ..
I guess that one is out of my range totally ..although the footprint map shows a distinct low power lobe extending accross the UK ..
cest la vie ..
I think you have total UK capture/bragging rights to that one Pride ;)
Well done m8
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Done some tweaking ...and can just make out errr...something on the F15 at 3986V ...
verrry occasionally signal peakes to 1.5 db above the noise floor ..
Not enough for a signal ...but at least I know I'm on target..
Soooo frustrating ...
Perhaps its like Cholusat on 43W ..and has a peak point during the day ..
I'll keep monitoring ...you never know..
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hi Pride Might also be worth trying ...
4033 V
Sindh TV DVB-S 4340-3/4
Sindh TV News
Sindh TV
like the others you mentioned ...this one also produces occasional peaks to around 1.2 db above the noise ...
Nowhere near enough for the F15 ..but might yield results at your location..
rgds
VS
nelson_b
Contributor
Wow --:)
well done - i tried for this sat once or twice in the past - but not a hint of signal --
i will be having another go at it -
but i,m 50 miles further north than Vipersan so i don,t hold much hope
nice one pride21 - :-righton
Paksat-1R has only just gone into service to replace the dilapidated Paksat 1 (aka Palapa C1, HGS-3 and Anatolia 1 :D)
I would imagine Paksat 1 will be junked now - she was launched in 1996 & has had battery charging problems since 1998!
nelson_b
Contributor
couldn,t resist staying up - for a go at this sat
"bingo" :) same as pride21
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Well done Nelson buddy ..
Now I'm off for a good sulk ;)
I can only assume its the same problems for me ...as I always have regarding Eastern reception..
Something out there is causing obstruction ..
be it electrical noise in the direction of Manchester ..or local interference ...or simply equipment not up to the task .
But I do know that the further East I go in Cband ..the less I acheive..
Never seen Yamal for example ..and gave up trying some time ago ..
anyway enough feeling sorry for myself ..
Congrats to both Pride and Nelson ..
Maybe I'll have another go ..when I've constructed my custom scalar plate..
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
..Just activated the Dish eye ...
No point in trying it last night ...and don't want to leave it on long ..
Sun too bright ..and possible camera burn .
It would appear there are still too many leaves on the troublesome tree..
Dish is currently parked at 38 East ..and as you can see at least half the dish is obscured to the east of centre..
No wonder I can't get a result..
Maybe in the winter ..once the branches are bare ..
Unless someone wants to sneak round my gaff one night ..and steal a tree :D
rgds
VS
nelson_b
Contributor
rgds
VS
it could be arranged --l.o.l.
pride21
many thanks chaps,i will try 4340 VS, a couple of other transponders have about 47% quality but not enough to scan,i found Dhoom News to be the strongest last night at 53% quality but Sun TV at about 51% quality,the Sun TV came in a bit more when i moved the dish a bit more to the west,have you noticed that Nelson_B. cheers
nelson_b
Contributor
hi pride21 -
no i don,t notice that on my setup -- but both receivable transponders are stronger here for me tonight -
but i get no hint of signal from any other transponders that i have tried -
cheers :)
pride21
hi all a couple more channels from paksat on transponder 3814H,Indus music and Indus Vision,they are quite strong,one of the channels is blank. cheers
nelson_b
Contributor
nice one --
i,v looked at this sat a few times during the past week -- and i no longer get- dhoom news at 4055V and it was the stronger of the two that i could receive ( can you still receive it ? )
i,m only picking up sun t.v. now - and its very weak here recently
regards nelson.b.
pride21
hi nelson_b i think dhoom has left the sat.cheers
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
If I might quote Frazer from dads army ..
Aye ....we're dhoomed ..we're dhoomed I tell ye
I certainly was ...as I never got a squeak of a lock on this bird..
pride21
hi all have received these channels this evening,Haq on4145V 2170 and Health on 4177V 2800.cheers
