Can we have the results from the Norwegian jury?
Here are the results from the Norwegian jury :-) :
Trondheim Norway (63,4N 10,4E)
Below I repeat my report from 22. november.
In clear sky, for the last 18 hours: Last evening 52%, this morning 46%. I have not noticed a significant change of signal strenght since the 22nd of november. It is stabile and give med uninterupted picture and no problems or fades.
It seems like 2F has the same signal strenght as 2D used to have, 1N has made us into spoiled children
To anyone at the west coast of Norway having trouble with receiving 2F I would recommend a bigger dish :-), maybe 90cm or 110cm is enough there.
Trondheim Norway in light rain, using a Dreambox 8000:
1.8m dish 11024H 8.6dB or 49% (Astra 2D used to be between 50-60% on this dish, the limit for receiving any useable picture is about 36%, H transponders on 2D were under this level some times)
1.1m dish 11024H No signal
Example from 1N, under same conditons:
1.8m dish 10847V 13.3dB or 76%
Generaly the 1.1m dish receives Astra 1N with signal around 60%
