30.5E (Arabsat 5A)
Anyone got a current strong frequency for this one I can have a go for?
I did have one I am just setting all sats back up, I will tune back in if no one shouts up :-)I am just scanning atm.
check:
10766V, DVB-S2, 30000, QPSK, 2/3 (data)
12724V, DVB-S, 3000, 3/4 (Ashorooq DSNG KR)
Cheers lads - cant even find 28E yet so 30.5E will have to wait a bit! :D
The elevation adjustment is certainly a bit wayward on these Triaxes.....
We did warn you!
Tip: If you hold the bottom edge of the dish with one hand, and use that alone to alter the elevation, you'll find it slides much more easily than if you also have hold of it elsewhere. The trick then is to hold it steady while you're tightening the slider with your other hand.
Even better if you can pat your head and rub your stomach at the same time.
Didn't I mention something about tearing your hair out?
Just imagine fannying around with it while balancing on top of the ladder reaching up above your head - I didn't have to imagine.
Then the spits of rain into the eyes - the horror, the horror!
Tip: swear a lot, you'll feel better.
Already discovered the hand at the bottom of the rim trick. :D
Wouldnt want to install summat that big up a ladder - its too damned heavy
I'm sure there's an Off-Topic response available here ....................... :-shh
Not to mention several emoticons. . .
:-shifty
Nothing on those frequencies above
Will have some breakfast then I'll set my stuff up outside - looks like its going to be a reasonable morning here.
Determined to find 28E today!
Not a phrase i'd expect to hear from the zip clip king!
Thats just my starting point :-rofl2
And now - I may be gone some time
Not much of interest on 28E, AS.
Map TV on 33E now found :D Now I'll try back west for 31.5 & 30.5
Sliced my hand open on the bloody Triax as well :D
