Hi Guys
Right here is the update.
From 28e to 5w, I checked and fine turned the lnbs to approx., 80 to 85% across a number of the tps within each lnb.
I did not get anything higher no matter what I tried, so left them as that.
I did this on my S9HD openbox and the signal quality also varied from 60 to 85% for all tps.
So I was happy with the results, since I only wanted to spend a couple of hours doing this, but ended up nearly all day.
So next came the 16/1 box with the dips in the right position up, down, down and down. I had the lnbs spaced on each numbered input and did 1.1 diseqc on the vu+ (I first checked that the lnbs where showing up on the vu+ with the sat signal checker and so far so good).
Plugged them into the 16/1 box and wired a couple of lnbs up and nothing.
Advanced, 1.1, same inputs for lnb and 16/1 box eg. 28 as input 4 and lnb4 and so on. I did uncomm.comm.tone, and repeated for the 2 lnbs to test. Nothing!
So wanted to see if a emp 4/1 would work and put that on via simple diseqc a,b,c,d and tuned in 28.19.13 and 0.8w and they all worked infact retuning now to get some better figures.
Can anyone help to see what going wrong with my 16/1 box setup of anyone got a beginners guide as it not working.
Some figures
28e got me 963 channels on the vu and 830 on s9hd
19.2e vu- 1609 channels, - 1340 on s9
0.8w vu- 296 channels, - 677 on s9
13e vu- 2208 channels, - 1847 on s9
Can anyone how confirm if I should be scanning more on the vu+.
Really need the help on the 16/1 box.
I did both uncomm and comm
how do I do screenshoots again.
I got everything back in the house now and wired the 4/1 on at the moment. The 16/1 is sitting on the floor at the moment until I find a guide on how it works.
I need another day now to try to put back on
