- Tel Aviv, Israel
Too busy in the swimming pool, solly?![]()
we go to out to fresh air
resturant
10942H Is it 100% confirmed, is what I see in Madrid (spain), that satellite??Is this 10942H really from 2E, or could this be just shadow signal from upper frequency band 11792H ? (actually 11798H Sky TP). In Finland that 11798H is very higher related to 1N/2F in Finland.
Here is constellation diagram from this 10942H:
But what are the signal levels in Rover meter for that Sky TP (11798H) ? As LNB can leak that strong signal into lower band.10942H Is it 100% confirmed, is what I see in Madrid (spain), that satellite??
Tests on low band H in tuner to avoid seeing errors Channel5 band change polarity, the analyzer is in external power mode to avoid errors, the LNB powered DB800S-HD tuner.
I understand the accounts.![]()
10942-9750 = 1192Mhz.
1192 +10600 = 11792Mhz.
By comparing measurements Channel5.
DB800S HD.-10964-H SIGNAL SNR56%...... AGC99%.... BER3.... 9'00 dB Channel 5
Vu + DUO2 (tuner3) -. SNR56% ......SIGNAL AGC69% .....BER0 .....Channel 5
Spectrum analyzer Rover SRM-50 -..... 74.3 dBuV.
Impossible to verify with certainty, but why would they be testing a carrier on that frequency between the adjacent 1N and 2F transponders if not 2E?10942H Is it 100% confirmed, is what I see in Madrid (spain), that satellite??
hoi,Chap on Robert's just posted 11728 V 27500.Possible 2E pe beam?
hoi,
11728 v is wrong
is 11739 v
@Hug: Source is quite close to home. I wrote it on my own site, based on the SES press release and accumulated knowledge, with the help of contributors here and other places..EUROBIRD TO CLOSE
SES has revealed in a press release today that all Eutelsat's Eurobird satellite channels will be transferred to SES Astra's fleet. This follows a long-running dispute between the two rivals over who had the right to operate a section of the satellite spectrum at 28.2 east. Eutelsat will still carry the current package of channels, except they will be broadcast from Astra 2E, 2F and 2G.
What does this mean for viewers? In the British Isles, Eurobird is weaker than in mainland Europe. Its frequencies are often affected by rain and interference. Transmissions from the new generation of Astra satellites will be more powerful within the UK than at present.
In the east of Europe, Scandinavia and eastern Mediterranean, expats may well lose Sky completely. (see beam maps below) Astra 2A will close. Its south and north beam channels will be moved to the new satellites. This may mean weaker, but not loss, of signals for most paid-for Sky channels in Southern Spain, such as Sky Movies and Sports.
hoi,
11728 v is wrong
is 11739 v
Where?100 Q....90 S on..11728...and 14 no name chanells......?........
A picture is better than 1000 words.But what are the signal levels in Rover meter for that Sky TP (11798H) ? As LNB can leak that strong signal into lower band.
the 11739v signal 8.3 c/n
