- May 29, 2009
- North York Moors
Bavaria!! So in Frankfurt you should be fine!Tony which Neuburg Bavaria or Rheinland ?
Welshman - I've been holding off buying a new dish for my system in FFM (Bornheim). With my current 60cm I get all BBC but the 5 channels are intermittent. How is your 80 cm dish with rain fade? Would 1 meter or even 1.25 meter be preferable or overkill do you think?SNR now at 66 %for. BBC 1 Hd
Unless we have torrential rain i have 24 Hour reception of 2f so 80cm is ok....125would help whenWelshman - I've been holding off buying a new dish for my system in FFM (Bornheim). With my current 60cm I get all BBC but the 5 channels are intermittent. How is your 80 cm dish with rain fade? Would 1 meter or even 1.25 meter be preferable or overkill do you think?
Since UK is "Western Europe", I don't see any particular difference to signal levels on BBC channels on my mostly obscured 1.2m dish.
