Could it be just a coincidence they are 8PSK or a combination of 8PSK and being on transponders that just happen to be a little weaker in your area?Anyone got any idea why 10847V and 10935V (the 8PSK transponders) should be so much lower for me than the rest. Up to 1.3dB lower. Originally I thought it could be stability of the LNB, but 8PSK transponders on 2F perform the same as QPSK ones using the same LNB. Any other thoughts what could be causing this?
it seems to be a universal issue, as those 2 tp's are significantly lower here, in hungary as well. like in budapest, some tp's are only missing a bit from locking on a 4 meter dish, while these 2 are nowhere near: 10773h is the strongest with 35%, some others are in the 20's%, while 10847v is 15%.Anyone got any idea why 10847V and 10935V (the 8PSK transponders) should be so much lower for me than the rest
cant do it, sorry. i dont have the equipment. i'm getting reports from other satellite enthusiasts around the country, i'm in touch with them. i'll ask around if anyone can provide a spectrum print.Tothbros can you print a spectrum for your location.
Is this ATOS the French IT company that is in charge of kicking people off the sick?All BBC TP's are uplinked by ATOS, ITV's by Arqiva, sounds deliberate to me. Interesting though.
No that tp's compare measured on the spectrum analyzer, have similar levels Madrid, normally the difference is usually the SR against lowest asking more antenna if you compare the tp's 22000, 23000 to 27500, these last give you more level.Anyone got any idea why 10847V and 10935V (the 8PSK transponders) should be so much lower for me than the rest. Up to 1.3dB lower. Originally I thought it could be stability of the LNB, but 8PSK transponders on 2F perform the same as QPSK ones using the same LNB. Any other thoughts what could be causing this?
Once they get this up and running us expats & other uk tv fans may be able get back what we have lost!
And this time keep it for good !
A Dish In the uk with a satip lnb connected direct to a router.
Multiple satip enabled stb.s,tablets and phones wherever you are in the world
http://www.ses.com/satip
http://www.satip.info/
http://www.ses-gs.com/bandwidth/sat-ip-capabilities/
Would love to hear of anyone with a large dish trying this and getting a result in the null we have here.
You can do the equivalent today with a slingbox.
Yes you can but apparently the remote control part Is slow to respond and In an ideal world you would need a sling box connected to a freesat or freeview dvr to series record etc and then a good media player to connect to your tv abroad and again the remote control is not great as you would need to use another device like a wireless mouse or something ! Very messy !
If you could just have a normal dvr with a normal remote control under your normal tv then It would be much easier ! + you would have the benefit of streaming to tablets etc in other rooms as a bonus!
As already stated, 11023H, 11068V & 11097V (2F) do not suffer from this effect. These transponders have identical parameters to 10847V & 10935V (2E). If the receiver were responsible it would show on all these transponders.Pero no usan el mismo sintonizador DVB-S/DVB-S2.
Mostrando valores distintos.
