Astra 1N at 19.2E
first move next two day
Retired Mod
www.timo.me.uk
Does anyone have a list of test transmissions from Astra 1N when it was under test in 2011?
adonis1
From my records 8th August 2011
ASTRA 1N
Following successful launch, the satellite is currently being moved to 28.2° East and will undergo testing before being made operational.ASTRA 1N will provide DTH broadcast $ervice's, notably digital and HD television. The satellite will offer coverage over Europe and will ultimately serve the German, French and Spanish markets. The satellite will first provide interim capacity at 28.2° East for the UK and Ireland before being re-located to 19.2° East.
Satellite Facts
Satellite launch information
Launch date: 06.08.2011 19:52
Launch vehicle: Ariane 5
Launch site: Kourou, French Guiana
Launch mass: 5300 kg
Satellite orbital information
Satellite manufacturer: EADS Astrium
Satellite type: Eurostar E3000
Orbital location: 28.2° east
Stabilization system: 3-axis type
Dimensions body: 6.5 x 2.8 x 3.2 m
Total power consumption: 13,074 W
Satellite transponder information
Transponder capacity: 52
TWTA output power: 130
EIRP: 54 dBW
All transponders are eclipse protected: yes
Transponder bandwidth: 26 and 33 MHz
Polarization: Linear (horizontal and vertical)
Channel capacity
With 52 active transponders to operate in the Ku band
Total Ku-band channels: 104
10.70-10.95 GHz: 16 channels (band D)
10.95-11.20 GHz: 16 channels (band C)* New part of the spectrum will become active,
11.45-11.70 GHz: 16 channels (band B )
11.70-12.10 GHz: 20 channels (band E)
12.10-12.50 GHz: 20 channels (band F)
12.50-12.75 GHz: 16 channels (band G)
11.20-1145 GHz Operated by Eutelsat Eurobird-1 (Not covered by Astra Satellites at 28.2 east)
11.45-1170 GHz ---------------------------------- (Now shared with Astra 1N)
12.50-12.75 GHz --------------------------------- (Now shared with Astra 1N)
Astra 1N is testing @ 4.3 east (22nd August 2011)
10967V
10812H
11003H
11109H
10820V
10832H
10852V
11028V
11040H
11078V
11174V
11446V
12572H
astra 1n take 12100-12480v
Retired Mod
www.timo.me.uk
Thanks for all the info. Just looking at what potential frequencies are likely to be used at 19.2E.
We can rule out 11.214H - 11.436V as this apparently isn't covered by 1N.
Also there was very little reporting of any tests between 11.739V - 12.051V and this band was never used at 28.2E by 1N either. Perhaps 1N doesn't have many usable transponders in this range.
Everything else was pretty extensively used at 28.2E or tested at 1.8E.
band b it be change ?
i hope band e not change it 1m wide beam
T.Tanilsoo
Satellite: 78 cm offset, tuner Xoro HRS-8500 Positions: 19.2°E and 13.0°E.
Computer: Samsung N220 Plus laptop, 1 GB RAM, Lubuntu 14.10 64 bit;
MicroLink desktop computer, Celeron 2000, 1 GB RAM; Lubuntu 14.04
Laguja, Estonia
M60
Northern England
i not get now 12522v,12580v,12640v
it down for me
T.Tanilsoo
Laguja, Estonia
Retired Mod
www.timo.me.uk
it down for me
All three are the exact same quality level as when I last checked on Saturday for me. No change here.
signal 1l now better then 1m
T.Tanilsoo
Laguja, Estonia
As of 0519 UTC, I haven't observed anything out of the ordinary with the signals yet. Checked 11953H and 10891H
Retired Mod
www.timo.me.uk
Lost a few 1L transponders from the top band 12.515H upwards and some are just locking on an 80cm in Helsinki. Will have a proper check and report back soon.
Retired Mod
www.timo.me.uk
These look like the changes from last night (I think all were 1L transponders). Reception on an 80cm in Helsinki with a DrHD F15 and Black Ultra LNB. In brackets reception from last week in similar overcast weather conditions.
It looks like the signal is fading. Hopefully it'll pick up later on.
92 1L - 12.246V - Now 8.3dB (was 12.1dB )
105 1L - 12.515H - Now 3.8dB (was 12.3dB ) No lock
106 1L - 12.522V - Now 6.7dB (was 12.0dB )
108 1L - 12.552V - Now 6.0dB (was 12.4dB )
110 1L - 12.581V - Now 6.4dB (was 12.3dB )
111 1L - 12.604H - Now 2.5dB (was 11.4dB ) No lock
114 1L - 12.640V - Now 5.0dB (was 11.9dB ) No lock
116 1L - 12.670V - Now 5.8dB (was 13.0dB ) No lock
119 1L - 12.722H - Now 3.2dB (was 10.6dB ) No lock
Biggest loss today for me was Sky News on 12.604H which looks to be the weakest transponder of the lot. Will have to look at setting up an LNB for 1W.
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
Acc. to Flysat 12246V/29700 is moved to 1N.
12246v- 6.5db now was0
12522v 6.7db now
12551v 6.3db
12580 6.2 db
12640v 6.0db
12662h 5.6db
12603h 6.3db
for 11876h no lock signal any more
