Astra 2E: Western Europe Reports
stephenG
Echostar HDS-600RS, Topfield 6000F, 150cm Gibby dish + "twin dish"quad LNB & Gibby feedhorn;
Grasse, France
Hi StephenG......The Opticum Quad you want ....is the LQP 04H ......a great LNB ....I hope you have success with It...
What is the make of the cheapo LNB you are using at the mo...??.....
http://www.amazon.fr/Opticum-universelle-récepteur-satellite-Allemagne/dp/B002E3Q4JC/ref=sr_1_1?ie=UTF8&qid=1400825539&sr=8-1&keywords=Opticum quad
Thanks, that's what I've ordered.
The cheapo quad LNB I am using, which I bought years ago from BFSAT.fr, is branded "Twin Dish". Just like like this one....
I'll let you know the results.
stephenG
Grasse, France
The PLL one was the LNB involved in the IBU comparison test I did. I've also got the quad above and did tests on Astra2 using a small dish with it. Without trawling back through this thread to find them, the results will be on an early page I think. I think it's unfair for me to compare what I find with Steve, due to the differing locations and dish sizes involved. I can only say that overall the results didn't persuade me to change from an IBU for fringe stuff.
@Stevesteve : You'd do better to advertise those surplus BU's on here rather than throwing them away. I'm sure plenty of people would snap them up.
The Opticum web site (http://www.opticum-gmbh.de/lnb/) only lists two models of quad LNB Red Rocket and the LQP-04H (which steve.steve refers to). Do you know the reference / model of the PLL version your comparison ?.
sonnetpete
wordpress.com
Normandy, France
stephenG
Grasse, France
sonnetpete
wordpress.com
Normandy, France
S
Steve Steve
This is..... all a bit confusing .....But Interesting..........I'm looking forward to Stephan and Judith's results.......
Ps ...thanks Stephan..for the link and pic of your cheapo LNB........I might test that one in the future ...Depending on your test results with the Opticum Quad........
IPBox
France
[QUOTE="
I think I will suck it and see with the cheapo LNB.... And the Inverto Black Ultra LNB can go back to Amazon.[/QUOTE]
stephenG I am in grasse and can probably use the Black Ultra if you want to off load at cost, let me know
stephenG
Grasse, France
[QUOTE="
stephenG I am in grasse and can probably use the Black Ultra if you want to off load at cost, let me know[/QUOTE]
Hi supermagagnosc, Sorry but it is already on its way back to Amazon (and they reimbursed the total cost within 6hrs of dropping of the return package at La Poste, how's that for service) . Since you are so close to me I am interested to know your own experiences with Astra 2E/2F Uk spot beam reception. What size dish do you have ?, what LNB do you use ?, what reception quality do you get ?. Thanks.
stephenG
Grasse, France
No problem steve steve Anyway some questions for you; you mention on this thread http://www.satellites.co.uk/forums/threads/opticum-white-quad-v-inverto-black-ultra-single.160026/ that a "Raven/Andrews feedhorn /invacom LNB...gave 10-15 % better Signal Quality than any universal LNB" and your avatar mentions "Opticum Quattro (DIY conversion to c120 flange ) Gibby FeedHorn".... so what do you use today ?, and what's your current view on the feed horn Vs universal LNB ?, also was the raven feedhorn better than the Gibertini feedhorn ?. I am wondering if it's worth playing with a feed horn, maybe along the lines of your Opticum Quattro DIY conversion (albeit not matched to the dish though). Cheers.
sonnetpete
wordpress.com
Normandy, France
stephenG: I'll let Stevesteve answer your specific question but I don't think that a feedhorn would be at all effective on a 1M dish. When I got the 1.2M Laminas I purchased at the same time, a C120 LNB and Laminas feedhorn. Tests soon revealed there was no better solution than an LNB designed for an offset dish (the Black Ultra has proved to be the best all round solution on that dish). I'm sure you'll get advice to the same effect. (though I'm willing to be proved wrong)
S
Steve Steve
That quote from me in From sonnetpete's.testing....was a long time ago...when things was very different ....1N was still transmitting at full power and my only problem channels were Channel 5 & Channel 4 HD........Now i have many more problem channels..!!
Im currently using A Gibertini Feedhorn and my converted Opticum....as this combo gives me ..a little bit extra on Channel 5 and itv 1 HD evening reception ...over the performance of the Invacom c120 and Raven feedhorn....There is not a lot of difference .... but just enough improvement to get through the evening low signal......
What would be great is a combination Of a Opticum , Inverto Black Ultra and a Invacom LNB's..all in one...That would be Perfect......Opticum is better on ch5....Inverto is slightly better on some BBC's...and the Invacom's C120 Flange...!
I would not have thought a Gibby feedhorn for 125 cm & 150cm dish..... would give any advantage on a 100cm dish...But I've never tried it.....You would.....Probbably be wasting your money with that idea
S
Steve Steve
For anyone who's interested ...Here's a couple of pic's of one my DIY Opticum C120 flange LNB's I made .....This is my mark 2 version with screw studs.....instead of screw holes....for better central tube alignment with the Feedhorn....
I very recently made another one ....for a Member of Robs sat site .....But I'm waiting to hear the results ....
FRINGE
Adeje in Tenerife
laminas 2.7 offset
laminas feed horn
Invacom quad LNB
Humax foxsat PVR
Tenerife
From my own research across the internet/forums, and from my own personal experience, it seems that C120 flanged LNB's with matched dish/feedhorn is most effective on larger dishes. That appears to be the combo that can outperform other 'top' LNB's - such as the BlackUltra. In my case the invacom quad and lamanis feedhorn works best with my lamanis 2.7 dish.
RichardinSpain
Totana, Murcia
Dreambox 500s motsat3 motor
Totana Murcia Spain
The Inverto Black Ultra LNB arrived today and..... after an hour on the roof again... no signal, 0%, diddly squat, for UK beam 2E or 2F transponders. But the cheapo LNB gives 70% signal quality on most transponders, incl CH5, I can just HD but not stable..
Hi StephenG
This is what i found with the Black Ultra too, it is a good lnb and on some transponders it does improve the signal. When i hooked it up to my motorised dish it was getting a 10% more signal on some transponders on Nilesat but when i put it on for 2e and 2f it just didn't cut it on the transponders i was interested in, thats why i put my B.E.S.T lnb back on..Having said that i think the BU does out perform a lot of lnbs but my B.E.S.T lnb has the edge
stephenG
Grasse, France
Thanks for your feedback steve steve and sonnetpete. I understand that I am clutching at straws and in reality bigger is always better - however I fear the problem of permission from the local planning office.... perhaps I should tackle my fear head on...
sonnetpete
wordpress.com
Normandy, France
....however I fear the problem of permission from the local planning office.... perhaps I should tackle my fear head on...
Is this 'permis' problem something local or an unheard of (to me) regulation applied nationally. I have five dishes of various sizes up to 1.2M and never had anyone from my local commune (village) to check. I am pretty secluded with no near neighbours though and have only had the mayor down here once in over 12 years...
S
Steve Steve
After last nights total loss of all spot beam channels :-( .......In desperation .....Ive just spend a big 20 Euro on a Octagon Quattro LNB with PLL......With the very optimistic view it might give something extra......
The Octagon is more than twice the price as a Opticum Quattro (8,50 Euro )....So It Might Be twice as good..?.. :-) ....Fingers crossed....
I'll post my findings next week.........If its better than the Opticum ....I'll convert it to Feedhorn c120 flange ...the same way i did with the Opticum LNB......
stephenG
Grasse, France
If the dish is fixed to outside of a building and the reflector is greater than 1m then permission needed under the "déclaration preable" regime (like for a swimming pool for example) - national urbanisme regulations. Otherwise there are also local (commune) urbanisme rules for any modification to the exterior aspect of building - it may need to comply to specific rules, ...
If the dish is on a pole / mast in the garden - then this is different . No good line of sight except on the roof or in the middle of driveway for me ....
S
Steve Steve
Huevos..." Absolutely no way"..... Says Who...???.....really....?????.........you forgot ....to include... "In your opinion".....TBH....Ive wasted enough money on testing IBU's....and other crappy LNB's from " Inverto ".....a very overrated LNB for fringe reception of 2E & 2F...In my option / experience .....As others have also on the fringe of UK TV reception have also posted....
Huevos....i imagine you are based in the UK ...right.......??...with no prpbs with 2E & 2F..?.....The IBU might be a wonderful / the best LNB on other satellites ...but for me on fringe 28,2 reception...The IBU...is not even in 2nd place....... B.E.S.T...And Orton Quad's... ..also are also better on Difficult PSB's reception.........sorry.... IBU 4th place....If that....
