Archive-8
I have an old credit card I could use
Or I have some inverto 23mm lnb's they are ment to have a dielectric plate inside them. I could try that?
Do you know what the cost would be in £?Pretty sure 23mm LNBs have the same throat as 40mm ones, so why not.. I found some circular LNBs here. It's all in Russian but I can probably get one if you really want it...
So at least, you will have LNB's to properly receive data transponders of the seriously inclined AMC-14 @ 29.5° East!
