11W (Express AM44)
BlindFaith
TBS 5925
I found and fixed the bug (being unable to switch to a particular PLP in a T2-MI transmission received by XTASI-S2+and TBS. Version 0.9.61 is ready for download (http://www.4t2.eu/ccount/click.php?id=1).
The reason was a too small buffer, which was not able to take one bunch of the hardware. BTW, it was reported in the log file as a continuos "internal buffer overflow" .
I was able to use the T2-MI test stream on 5W, 12669 H, DVB-S2/8PSK, Root 8 which contains one PLP with the RS "Diver" in.
Please, next time you run into trouble, let me know earlier.
Doesn't work here. 0.9.61 is still freezing after trying to open the PLP on this transponder.
  • ABC4T2ContentAnalyser_0_2014040410.zip
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
anyone having issue,s with these 3 txp,s today as all im getting is black screen on my TM F3/5 ? ive tried a re-scan but its still the same and is showing scrambled channel
11.153.H.17141
11.185.H.17141
11.653.H.17141
edit looks like there scrambled now but showing as unknown so maybe B***
Looks like Roscrypt. Oh well, was good while it lasted.
adonis1
Russian distribution DVB-S2 muxes encoded at 75E and 11W with CAID 2809 , which is a system LCS LLC ??
These multiplexes are broadcasting for Crimea's needs .
Russian muxes still FTA on Yamal 402 @ 54.9° East .
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Yesterday I scanned 11*W and got 6 working frequencies. Everything was FTA, but not anymore. Signal levels attached. Screen_34 Apr. 27 19.52.jpg
It's Roscrypt
Something tells me they won't last long either! Really need to set up that dish for Eastern sats...
gibertini
up north
53.6N 2.4W
fta again now
11.153.H.17141
11.185.H.17141
11.653.H.17141
pontiend
Contibruter
south yorkshire
It is some time since I looked at this satellite.
The Dish was on 4W so I sent it for a look.
I get three data transponders.
11064H 2583 3/5
11082 H 3600 3/4
11590 H 1613 7/8
Three provider transponders
11548H 1555 2/3 Conad .No Channels
11557 H 4000 56
11565 H 7998 3/4
TBS6925 100cm Dish.
I look in on Conad TV often: Some great Offers.
pontiend
Contibruter
south yorkshire
Just got back from my night out.
Still getting no channel on 11548 H 1600 23.Conard tv
Quality is 90%.No channel scans in.
far78
1m Orbital and Supreme Intelligent Dark Motor, TBS 6925 and Tevii S464 PC cards, TM5402 M1
York, North Yorkshire
Just scanned it and yes, there appears to be a fault with the transponder somehow that means no channels scan in. Conad TV is active though on that transponder, as I can still tune into it from an earlier scan - most weird :(
pontiend
Contibruter
south yorkshire
The TBS is scanning 11000H to 11700H just now .When done I will swap the Dish to my TM5402HD.See what that gets.
pontiend
Contibruter
south yorkshire
Nope. TM5402HD getting 67%, but no conard tv.
TM5402HD 100 cm Dish.
Archived-1
Persona non grata
uk
I get a good signal on Conad but it does not scan in I also scan a channel Tagged Telepace 11553 H 1666 all day has just been a blue screen
Conad TV still missing this morning.
sonnetpete
wordpress.com
Normandy, France
I have 11W as part of the multisat, albeit as an offset on the 1M Gibi which is centered on 7.3W. No sign of Conad, the VU+ won't even scan it in. Telepace does register though still with a blue screen. Will try the Dr.HD shortly....
More or less the same results with the Dr HD..the TP for Conad locks with a strong 11dB but a scan reveals no channel.....
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
I am receiving it picture wise with Dr.HD 15F and Clarke tech 5000HD. (both receivers are clones to each other). But no Modulation Video & Audio wise with Dreamboxes 8000 & 800se. Signal is quite strong even with 1m Dish.
pontiend
Contibruter
south yorkshire
I get 9.4 dB on 11548h 1605.No channel scanned.
TBS 100cm Dish.
BlindFaith
TBS 5925
TBS 100cm Dish.
..it's not DVB compliant. There is no PSI (PAT, PMT), just video and audio ;)
pontiend
Contibruter
south yorkshire
Telepace is live just now.
11554 H 1666 5/6.
TBS6925 100 cm Dish.
