31E Avanti mux
Archive-8
[SATTYPE]
1=0310
2=Hylasat
3=5
4=0
5=21200
6=0
[DVB]
0=2
1=19732,H,45000,89,22,|11.9 (0.91) dB
2=20114,H,45000,12,21,|7.4 (6.1) dB
With the tbs card.
Archive-8
Has any one been able to lock on to this with enigma2 as my duo will not do it.
Archived-1
Persona non grata
uk
Hi Chris, I will put the Ka band lnb back on tomorrow and plug my e2 box in and check for you.
Archived-1
Persona non grata
uk
No problem chris, I am going to have to make room for KA band now on my new install I will probably just stack it above my ku, its got me hooked :D
Good find guys, but the only 10K SR I can find now on 31E is an ACM data carrier.
Archived-1
Persona non grata
uk
Hi Chris, sorry I can not check for you, just plugged the tm nano in that's been in its box for a while now and smoke came out of it :eek:, what a bag of sh*t this box as been, i will have to check if its still under warranty,
Nice to see the channels are still there if any changes on the mux will you post up please I am swapping lnb at the moment to check, still booming in here on the skybox:)
Found it. Too hasty before to check those tightly packed carriers. Squeezed between two ACMs :-rofl2
Using the Hughes LNB lump modded to vary the LO, so shown frequency may be a little out. Need to check with a known carrier.
Archived-1
Persona non grata
uk
I am going to have to strap the KA band LNB on now, I am itching to go out now lol, it will have to wait until morning.
Excellent Chris. Also on Avanti One And Two ;)
Looks like some decent English audio films there. Might just be tests, time will tell.
KA is content-poor at present away from 16E and 7E, apart from feeds on 19E and 5E.
Films on now -
Avanti One - Mr. Bean's Holiday with Rowan Atkinson
Avanti Two - Animal Farm with Pete Postlethwaite
Avanti 2HD - A life of David Gale with Kevin Spacey
Archive-8
What other sat's? 16e,7e,19 & 5?
How do I work out the freqs as boxes only scan the ka lnb set to universal.
So do I take away the l.o. Freq from the ka freq?
Other KA sats normally need different, more expensive LNBs. Check the various KA threads, plenty of info about using cheaper ones, for instance the Hughes and DirectTV LNBs from the US.
Frequency conversion from Ku to KA -
Inverto LO = 21.200 GHz. Subtract your KU frequency (11.765) from that = 9.475
Add to your KU LO Frequency - in this case 10.600. KA frequency needed = 20.045GHz
Also receivable on the DirecTV LNB with an unmodded SUP.
