Vipersan
Emmett Browns Ghost
- Jun 29, 2009
- Age
- 66
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
- UK
Ok ...
for anyone planning to create something similar by utilising Gbox innards..
This is important..
Yes you still need a smooth isolated 5v supply for the micro etc...
but you also need a 12v supply ..
I've found out that the relays will not function at 5v ...
Simply not enough volts and the 12v supply for the relays is used _before_ the regulated reduction to 5v ...
So ..
I will still be using a seperate negative rail isolated supply to drive a 7805 ...but instead of fitting a seperate 5V supply ..I will have to fit a seperate isolated 12v supply ..and still employ a 5V regulator to further reduce the 12V to 5V
Alternatively I _could_ start replacing the relays ...but too much work fwiw..
rgds
VS
This is important..
So ..
rgds
VS
