Rain Hood
Got one off these rain hoods of Amazon, keeps the droplets nicely off the Ku LNB but more especially the Ka LNB. They are made in Scandanavia, they must use them to keep off the snow. Good bit of kit
Journey
drx 890
look very cool indeed
£21.89 on amazon uk
Retired Mod
www.timo.me.uk
I've seen them in the shops in Finland. I have been tempted to get one myself to keep the worst of the snow off.
Terryl
Custom built PC
Well they may work to keep the stuff off the LNB eye, but what do you do about the ton of rain/snow/sleet/cows between you and the satellite?
We broadcasters have tried everything, we found the best bet to keep the signals coming was to go to bigger dishes, in heavy snow areas heated radomes were used, but when the clouds are chock full of heavy rain/snow or other things a bigger dish comes in handy.
But not much can be done when you get total signal blockage due to too much moisture between you and the satellite on a "Ku" band dish/LNB, this is why we went to "C" band, less signal loss on the lower frequency's due to water vapor.
One way I keep the snow/ice off my dish is to use a black heavy gauge lawn/leaf bag, slip it over the dish and stick a drop light in it with a 40 watt bulb, a temperature sensor for the pipe heating tape works to turn it on when it gets cold enough to freeze, a few tie wraps will close it up.
skomedal
This and that
thule
Works well protecting the LNB just wish dish designers altered feedarm design to diamond shape instead of thin/broad flat so the snow does not build up so much in nordic conditions/locations:-toilet
Regards
As much as I would like a bigger dish, SWMBO, has the last say...........
Terryl
Custom built PC
Regards
Just wrap it with pipe heating tape, it will melt the snow/ice off, you can get some with a temperature controller, comes on at or below zero "C".
I have customers at or above the snow line, I use stick on dish heater panels, (goes on the back side of the dish) heated LNB's and pipe heating tape, keeps things snugly warm.
I cut down a PET bottle a couple years ago when we had a lot of snow & stuck it with gaffer tape over the Lnb's it worked for 6 weeks until the snow went :)
skomedal
This and that
thule
Use that to keep the water pipes from the water well to the house from freezing during our 4 month winter:-rofl2
Regards
Archived-1
Persona non grata
uk
I find this is the best way for keeping snow ice and rain of my bigger dish :)
Its only recently that ive seen the rain hoods good idea :)
skomedal
This and that
thule
Does the wendy house move? :-doh
Regards
Retired Mod
www.timo.me.uk
Here's my home made cover to stop the rain drops forming on the LNBs (these 23mm type suffer when there are raindrops on the face).
It's been on for 2 years now and still working well.
parkiepie420
technomate tm-5402hd m3 /gibertini 1.25m sat dish 51e to 34w inverto black ultra single 0.2db lnb / titanium single output cband lnb
technomate tm-5402hd m3/triax 1.1m dish 53e to 24w inverto black ultra single 0.2 lnb
sheffield south yorkshire uk
to be honest I used a 3 litre coke bottle cut it down to shape and put this over the dish and this works a treat and a lot cheaper !!!
Journey
drx 890
Any chance of popping up a pic please
parkiepie420
no probs I will take a pic as soon as I get home !!
I should have said in my post " and put this over the lnb " NOT put this over the dish !! lol !!!
Retired Mod
www.timo.me.uk
I think I used a 1.5l bottle for mine (a few posts up).
I tried various bottles, but wanted something bigger as I may change the Ku LNB back to C Band, so need the extra space to accomodate the conical scalar.
parkiepie420
ive got the picture of the cover on my iphone how do I upload it on here ????
Archived-1
Persona non grata
uk
Hi pal, you will have to click on upload a file below , then go to the location of the picture in your phone and select it to upload, once uploaded select thumbnail image full might not upload due to its size,
