Regarding the uplink issue, I've often wondered why 2E is floating about at 28.3E on its own while the rest of the Astras are at 28.2E? There must be some good reason for it.
If what is described in this ITU Recommendation isn't the reason, then at least it is interesting to read!Regarding the uplink issue, I've often wondered why 2E is floating about at 28.3E on its own while the rest of the Astras are at 28.2E? There must be some good reason for it.
https://www.itu.int/dms_pubrec/itu-r/rec/bo/R-REC-BO.795-0-199203-I!!PDF-E.pdf
Astra 2E nominal is 28.35°E (not 28.3°).
One possible solution to the problem of adjacent channel interference is to provide a slight
separation between co-located satellites. A study performed in Canada showed that an improvement
in isolation can be obtained in the case of two satellites transmitting cross-polarized adjacent
channels by separating these satellites by a fraction of a degree such that they are seen as two
distinct orbital locations by the feeder-link transmitting antennas but as co-located by the smaller
receiving antennas. This removes almost completely the susceptibility of overall link adjacent
channel C/I to rain fades on the feeder links at the cost of a small gain loss at the receiving terminal.
The WARC ORB-88 decided that administrations could place the satellites of a same group of
satellites (i.e., sharing the same nominal position in the Plan) at any position no further than
0.2° away from the nominal position, provided that the agreement of the other administrations on
that orbital position is obtained. The advantage of this arrangement is that it permits additional
discrimination between feeder links (large transmitting antennas) whilst for the purposes of
reception of the down link (small antennas) these satellites can still be considered as being at the
same position.
Anyone heard of " Fag Papers "Thanks. It's a bit technical, but I guess the two key paragraphs are:
What sort of level in dBuV or in dB down from an adjacent carrier (eg TP66).a new "bump" at 11.112H has appeared.... probably in preparation of the new TP switches....
I'm seeing these at much higher level here in the UK, will measure them shortly once my Horizon meter has charged up (forgot to put it on charge last night!). Look very much like 2E UK spot here, the Freesat Home TP has much improved quality levels too.If remaining 28A have now transfered (at least signal is same worse as 11307V/H), those are now on 2F UK, not on 2E UK. As otherwise signal level is totally different from 2E UK...
What are you comparing it to? For me the 2F spots on 11.307/11.344 where much lower signal level to the usual 2F spots. The same could be for these new 2E spots. The only way we will know for sure is to check the signal variation over 24 hours, but I'm sure they are on 2E as I am not sure 2F can do these frequencies.If remaining 28A have now transfered (at least signal is same worse as 11307V/H), those are now on 2F UK, not on 2E UK. As otherwise signal level is totally different from 2E UK...
Interesting comment, we discussing this txp on the Iberia thread, where it appears much lower than other uk txps.12 422 H (2F UK?) is around 55-60 %.
