Yahsat 1A @ 52.5e (West Beam)
norm360
DM500S, TD88 Triax Dish + NH210 Motor
Anybody successfully received the West beam TPs on this sat in the UK? And what dish size?
No signal at all on an 80cm here. I can get the Europe beam stuff no problem as long as its not raining (along with Uzbek TV next door at 53E :D).
AS, what's with Uzbek TV? Do they show some odd fetish on the there or something. They speak Russian on that channel half the time so I understand it but most of what I've seen is rubbish.
digi247
NW
see sig
Never had a sniff of these on my 1.2 something a lot bigger is required me thinks, Thats probably why all the decent HD channels are on that beam
nelson_b
Contributor
hi -
had a try here last night under clear skies with C.M.offset 1.8 metre (view partially blocked by a nearby roof )
locked ok on 11785 H 27500 M.B.C. channels (encrypted ) - borderline lock today (as per the picture) -- cloudy skies
some signal but no lock on 11996 V 27500 Yahlive promo
only the slightest trace of signal on "some" other t.p,s
regards nelson.b.
I'd try it on my Fibo (if I ever get that working properly) but anything beyond 42E is obstructed by trees :(
Its just one of the countries Ive been wanting to be able to watch for a long time :D Ive been intersted in the old Soviet countries for a very long time - I used to listen to their English services on short wave in the 1980s
I just watch the pictures as I dont speak more than a few words of Russian.
wod
yorkshire
An excuse for a larger dish then would 1metre bring in 53e when it rains ?
Im pushing my luck with the existing setup with the landlord & the neighbours :D
Two dishes and some decent Humping coupling ?
Zorch
TM 5402 HD CI+ Super+
TM 6800 HD Super+
TM 5400 SD CI+ USB
QualiTv QS 1080 IRCI MPEG-2 [4:2:2]
Fibo 1.20m x 1.35m Dual-Offset Gregorian Antenna [30.0°W > 57.0°E]
Inverto Black Pro
Aston DS 200 Interface
LG 42LD790 HDTV
NW Midlands, UK
Hi norm360 et al,
I meant to post these pictures last week... but I got side-tracked and completely forgot about them... these pictures were taken on 29th Aug 2012
11.785H [27500] 5/6 DVB-S2 [QPSK] 45.3 Mbps [West Beam]
Signal Strength 97%
Signal Quality 54%
Best Wishes,
Zorch
Zorch
TM 6800 HD Super+
TM 5400 SD CI+ USB
Inverto Black Pro
LG 42LD790 HDTV
NW Midlands, UK
Hi norm360 et al,
11.823H [27500] 8/9 DVB-S2 [QPSK] 48.2 Mbps [West Beam]
Signal Strength 97%
Signal Quality 54%
Best Wishes,
Zorch
Zorch
TM 6800 HD Super+
TM 5400 SD CI+ USB
Inverto Black Pro
LG 42LD790 HDTV
NW Midlands, UK
Hi norm360 et al,
11.957V [27500] 8/9 DVB-S2 [QPSK] 48.6 Mbps [Europe Beam]
Signal Strength 97%
Signal Quality 90%
Best Wishes,
Zorch
Zorch
TM 6800 HD Super+
TM 5400 SD CI+ USB
Inverto Black Pro
LG 42LD790 HDTV
NW Midlands, UK
Hi norm360 et al,
I meant to post this picture last week... but I got side-tracked and completely forgot about it... this picture was taken on 29th Aug 2012
11.996V [27500] 8/9 DVB-S2 [QPSK] 48.6 Mbps [West Beam]
Signal Strength 97%
Signal Quality 49%
***NO LOCK***
Best Wishes,
Zorch
Zorch
TM 6800 HD Super+
TM 5400 SD CI+ USB
Inverto Black Pro
LG 42LD790 HDTV
NW Midlands, UK
Hi norm360 et al,
For some strange reason I could not get a lock on the following transponder on 29th Aug 2012 when I took the rest of the pictures... but I have nearly always obtained a good signal lock on the frequency each time I have visited this satellite at the right time of day (usually 6pm onwards).
However... I have looked through my picture archive and I have found a few taken on 10th December 2011 ...I know they are not exactly recent... but the O/P simply asked if reception of the West Beam was possible...
12.168H [27500] 5/6 DVB-S [QPSK] 4295 Mbps [West Beam]
Signal Strength 97%
Signal Quality 56%
Best Wishes,
Zorch
Eheimz
180cm PFA KU
57°O-45,0°W
Germany
Here on my position I don't receiver any transponder, but the 11,823GHz has got some remains so that you know, there was a signal.
The Europebeam is no problem...
Lasseparabol
3 m Prodelin
C band 25K Chaparall Sidekick
Ku band SMW X-line lnb
Chapparal Corrotor 2 Wide band
Echostar AD-3000IP
Dr.HD F15
Sweden south part
In southern Sweden, I receive the following channels, with a 2.4 m dish.
11996V (6.8) dB
11823H (9.1)
12169H (6.7)
11781H (9.1)
This cold and clear evening, since a long time, all except one transponders can be locked of the Yahsat West beam.
The encrypted MBC transponder 11785H remains by far the easiest with its 5/6 FEC, this one always locks during normal weather.
11862H, 11977H and 12169H are pretty similar in difficulty, normally just below lock, but tonight only occasional glitches.
(Dish is Triax TD-110, PC card TBS 6925. The Dr.HD F16 does not do well on these...)
Kveys
Southern Finland
What are the strongest frequencies nowdays, there in Nederland ~ Uk area, please? 11766V constantly freq. here during evening-night with about 5 dB (no lock). Also I get weak signal (125 Gibby) from 11747H and 12034V (only 3-4 dB and no lock either).
One finnish enthusiast obtained 180 pf recently (western Finland). I asked lad to test and 11766V strongest also there with stabile picture. Also almost all east-beam frequencies give signal. But fascinating news is that also 11862H watchable there. As far as I know it is Mena (west) beam. So both beams are possible far away here. (sure Europe-beam would be strongest if it exist still).
How about @hvdh , @martin-f and others..?
Kveys
Southern Finland
