Inverto Black Ultra HGLN
4wd
Getting the picture
5 W, 9-13-19-28 E
ref is this lnb good with Gibertini dish size 150cm?
Got the single and twin.
Initial testing the high gain twin on the 125cm and 28e, first impression is excellent. Quality levels went up to 'never seen before', some %'s better than my previous bests (Maximum XO), & much better than the regular BU Quad I've tried previously. Will be interesting later today when the normal evening level fade sets in.
Clown man
28,2 & 19,2 on Gibby 150cm ..2x Opticum Premium LNB's....Opticum 5x12 Multiswitch....Humax Freesat HDR's custom FW ...Pioneer Kuro & Panasonic Viera W60 Plasma tv's
Munich.....Germany......
Great stuff 4wd.......spending your time and money to test stuff out for yourself..,,,,.thats what i would do/did ....as LNB performance on the spot beams does seem to depend on location.....Good luck....
Looking forward to your evening results........!
4wd
Getting the picture
5 W, 9-13-19-28 E
The ultimate test here is getting BBC 4 HD on 2G without breakup, and the Ultra HGLN twin is delivering. Did a short HGLN single test, similarly good. So far excellent, the twin is staying on the dish.
Maybe just a few %'s better than other lnb's tested, but these %'s are crucial when the levels 'go away' in the evenings here. If it is for some Astra 19e reception (or daytime 28e) any old lnb would do, but for 28e fringe uk beam the small lnb differences & %'s makes all the difference in practice. So looks like I can still postpone getting a bigger dish for a while more.
Will come back to this with an update after some days in use, shifting weather\rain\snow.
Archive4
Could explain why the IBU singles have gone downhill of late, to make room for their new kid on the block
skomedal
This and that
thule
Fringe reception on Astra 28e uk spot beams is also null zone dependent.
125 gibby astra 2e uk spot, tried numerous lnbs ( ibu single and quad, ivacom twin ( waste of time and money ) triax quad, maximum quad and single XO etc etc etc.
Get signal astra 2e uk spot until ~1750cet when it does its daily wobble, then resort to streaming.
Clearly more metal required but find streaming much cheaper:D
Central southern norway close to the first ( pinch of salt ) null.
Regards
sonnetpete
wordpress.com
Normandy, France
4wd, is this really a new model of IBU or a rebranding with the HGLN (High Gain Low Noise?) added?
4wd
Getting the picture
5 W, 9-13-19-28 E
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
I have an old one here. It has "High Gain Low Noise" on the label.
4wd
Getting the picture
5 W, 9-13-19-28 E
A few days of use. Twin 28e, single 9e. Both giving a few more % Q than anything else tested, nothing revolutionary in terms of numbers, but adding a few crucial %'s for 28e uk evenings, and for 9e French hd's in very bad weather.
Both clearly better than the bu quad's I've got (which had problems with marginal levels), the single and twin seems to churn out a picture from the last bit of useable signal. Excellent.
4wd
Getting the picture
5 W, 9-13-19-28 E
Argh! Happiness never lasts ;O)
The Inverto twin suddenly got a constant drop in V level output, H fine. Tested on several tuners. Still fine for strong transponders (28e europe), but the V UK's going down the drain. Fitting back the Maximum xo twin the V's came back fine.
I suppose just bad luck with this particular unit, am still planning to order a few more of those BU twins.
nelson_b
Contributor
Hi - @4wd -
Had similar issues in the past with a Inverto BU twin - mine went a bit weak on both V and H :(
so went back to a single BU ultra - after finding that a C120 black pro twin + feed - that i used for a while was good --- but was completely missing some frequencies ??
Its not put me off them though .... iv just fitted another BU ultra twin again recently , as they are not that expensive, and to be honest along with the single , give me the best all round performance on my 1.8 C.M. offset:)
Archive4
Hi - @4wd -
I´ve found that the IBU singles miss some frequencies, did post it on installing dishes in Spain thread, I think!
Will have a look to see if I can find it later, but I have noticed it in the past.
samoloko
1.8 PFA
EU
Hi - @4wd -
thanks for that Info
are you using Inverto BU only or modified with Channel Master feedhorn
would you post a pic or two from your channel master 1.8 polar mount
regards
Clown man
Tho the single IBU is a good one ..!
My experience with the many Inverto LNB products I tested (Pro ,quad /Quattro /C 120 etc )has just been disappointment after disappointment ..total waist of money.!
There are many other better twin or quad LNB's available out there....
Best avoid anything with Inverto written on the box......unless it's a single IBU ..!
skomedal
This and that
thule
Totally agree having used numerous brands and variants of LNBs for fringe reception @ 28e astra 2E from my location, this was one of the better ones, but the midget maximum single xo on my gibby 125 easily beats the competition and much cheaper.
Just my opinion.
Regards
Retired Mod
www.timo.me.uk
I have to agree with that actually, the single has been the only one I've been happy with for weaker signals.
If I need more than one output then I go for an Opticum LQP 04 H quad, which I think you brought to my attention a few years ago.
Clown man
Timo w2s...you have a good memory.! ..yes ...it was probably me. :-) recommending the Opticum quad ...cheap and works great with fringe reception ......hopefully 4wd might test one ? :-) ...
Ghostleader
Glasgow,ish!
Opticum you say, looks a good bet for me, I'm needing a quad.
Sent from my Lenovo TAB 2 A7-30F using Tapatalk
nelson_b
Contributor
Timo w2s...you have a good memory.! ..yes ...it was probably me. :) recommending the Opticum quad ...cheap and works great with fringe reception ......hopefully 4wd might test one ? :) ...
Hi - Thanks Clown man ... Just ordered one of these to try on the 1.8 offset -- as the price is right and fringe reception is the area in which i like to play ... :)
must say that the new IBU twin is showing equal results to the single IBU that it replaced...so far ......l.o.l.
but as i say i,v had reliability issues with some inverto,s in the past.
will be more than happy if the Opticum beats it on this dish ;)
although i,v good results in the past with inverto,s on the 1.8 CM .... its not the same my 1.2 Channel master dish .. other l.n.b. setups have out performed them .......
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
...... recommending the Opticum quad ...cheap and works great with fringe reception.........
Agreed.........superb LNB, had one on the 1.8PF for months and as shown in this thread.
55.5w
Hope you get the results you want 'nelson_b'. :)
